07-10-2016, 11:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1980910 Status: Offline Sonork: 100.1650130 Thanks Meter: 35 | Ginger G4001 Silver Flash File Needed Chinese Miracle II [MTK module] v 1.51 Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : 0xB5B4A2982C3CD80503D92C3482B8B1A3 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : SIMDO ProdName : j1501 ProdModel : G4001 BOOSTER Device : j1501 AndroidVer: 4.4.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.ICS.MP.V2.30 SECURITY : IMEI_SW [1] : 9EA1B0E27159DBF IMEI_SW [2] : 9EA1B0E27159DBF BTMAC Addr : FFFFFFFFFFFF WiFi MAC : FFFFFFFFFFFF Done! Elapsed: 00:00:11 Reconnect Power/Cable! Set Is hang on logo After Format Still Same Can Anybody Provide Its Stock Firmware |
