03-03-2016, 16:00 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Ginger g5001 peacock privacy lock failed Chinese Miracle II [MTK module] v 1.41 Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530018DCA637F22DB Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530018DCA637F22DB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 8075F4A6F0B3348824A87D22AB979705 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : rtech72_we_72_kk ProdModel : rtech72_we_72_kk Device : rtech72_we_72_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Last edited by umarmsn; 03-03-2016 at 16:10. |
03-03-2016, 16:25 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Seems phone connection lost, try with other cable/usb port. What is the result with read Factory Firmware? Add C:\InfinityBox and it's sub-directories to Antivirus exclusion list and try again. Br. Infinity Box Support Team. |
03-04-2016, 06:54 | #5 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Card found : S/N : 0D63E285 , v0130 Chinese Miracle II [MTK module] v 1.42 Operation : Reset Privacy Lock [ v1.42 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530018DCA637F22DB Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530018DCA637F22DB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 8075F4A6F0B3348824A87D22AB979705 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! problem soloved thanks to cm2 team |
01-14-2017, 11:32 | #12 (permalink) |
Freak Poster Join Date: Aug 2013 Location: roorkee Age: 23
Member: 2006027 Status: Offline Sonork: 1645658 Thanks Meter: 36 | wrte this |
01-25-2017, 08:37 | #14 (permalink) |
Freak Poster Join Date: May 2013
Member: 1935677 Status: Offline Thanks Meter: 22 | Ginger g5001 peacock flash file [QUOTE=babu lal saini;12300964]write this enjoy by Safdar ali [URL="https://drive.google.com/opendrive.google.com framware file need without password ya give me password pleasssssssssssssssssssssssssse |
02-05-2017, 09:28 | #15 (permalink) |
Member: 2006027 Status: Offline Sonork: 1645658 Thanks Meter: 36 | paswword 9837945241 [QUOTE=babu lal saini;12301002][QUOTE=babu lal saini;12300964]write this enjoy by Safdar ali [URL="https://drive.google.com/opendrive.google.com framware file need without password ya give me password pleasssssssssssssssssssssssssse[/QUOTE] 9837945241 chek this paswoord |
The Following User Says Thank You to alamtelecom458 For This Useful Post: |
