02-12-2016, 15:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | gionee e6 imei 1 done imei 2 invalid here is log Start at : [2/12/2016 / 3:14:56 PM] Operation : Repair Security [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 82 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B000115303055388537034DE1317020 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U8 [eMMC] : FLASH_CID : 1501004B385530304D033785207031E1 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 000070000000000 IMEI [01] : 000070000000000 Set IMEI [00] : 8628454xxxxxxxx Set IMEI [01] : 8628454xxxxxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 82 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:03:56 Reconnect Power/Cable! Finish at : [2/12/2016 / 3:18:55 PM] |
02-13-2016, 06:58 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Try to write working NV and then repair again. Also you can try to Repair Ext Data and try again and check, in rare cases it helps. Br. Infinity Box Support Team. |
