Old 11-17-2017, 13:20   #1 (permalink)
Member: 2592600
Thanks Meter: 17
Gionee F103 Network issue, Not done
Repaired baseband, write security, read nvram from a working phone yet no imei on phone but show when reading security info....
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 510001154D5332380B360042619A6BDE
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMS28
[eMMC] : FLASH_CID : 150100513832534D4200360BDE6B7261
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0CE0470BDFE0F3F433FD3B6DB7857EE3
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 868510021336572
IMEI [01] : 868510021336572
Set IMEI [00] : 356645398704231
Set IMEI [01] : 356436498707781
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 15 ]
Sync...
Device boot not done
Check Drivers
Try again
Error while post-checking procedure! Check drivers and battery charge!
In some cases - need reconnect mobile (just re-insert cable) on this step
Reconnect Power/Cable!
cc; jaydi
Old 11-17-2017, 20:51   #2 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 494
Post here backup nvram from working device
Old 11-18-2017, 03:57   #3 (permalink)
Member: 2592600
Thanks Meter: 17
https://mega.nz/#!0NYkGToI!3u9faKBwH...iTZHHuaQQJTT2c
Old 11-18-2017, 06:37   #4 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 494
here a tip erase all flash them write a good FW and nvram from working device too and repair BB and post here result if not work its Hardware problem i have one with imei null and haved tryed all tips but nothing work for me still null
Old 11-18-2017, 09:24   #5 (permalink)
Member: 2592600
Thanks Meter: 17
Sometimes when I erase all... Cm2 can't flash again
Sent from my C1001 using Tapatalk
Old 11-18-2017, 11:20   #6 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 494
just keep preloader alive and make FW backup from working device
Old 01-21-2018, 13:01   #7 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 494
help me someone writed still null
Old 01-21-2018, 14:13   #8 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,089
check baseband if unknown then repair it first
Old 01-21-2018, 14:59   #9 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,025
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Wait for phone...
Phone found! [ 15 ]
Sync...
Check Drivers
Try again
cc; jaydi
Hello,
Full Erase and then flash with latest version, that's enough to bring Baseband to alive state. You can also try Repair Baseband -Fix Unknown Baseband (With/without BB deep fix) option in CM2MTK module.
After write NVRAM (if required) and repair security.
Tested NVRAM attached.
Br.
Infinity Box Team.
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 0.32589 seconds with 8 queries
