04-01-2019, 09:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Gionee f3 not supported, loader needed KINDLY HELP ME FOR GIONEE F3 LOADER THANKS IN ADVANCE Card found : A6936825 , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 72A2E996 ID_BLOCK_L : C58F7967EF4192FE14BD899275AF31DA ID_BLOCK_L : CE584386DB8DB36E3C3E4038152351BF Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
04-01-2019, 14:58 | #4 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : version:0.5 INFO : battery-soc-ok:yes INFO : battery-voltage:3669000 INFO : variant:MTP eMMC INFO : secure:yes INFO : version-baseband: INFO : version-bootloader: INFO : display-panel:nt36525_innolux_video INFO : off-mode-charge:1 INFO : charger-screen-enabled:1 INFO : max-download-size: 0x1ff00000 INFO : partition-type:cache:ext4 INFO : partition-size:cache: 0x18000000 INFO : partition-type:userdata:ext4 INFO : partition-size:userdata: 0x57fb79e00 INFO : partition-type:system:ext4 INFO : partition-size:system: 0x100000000 INFO : serialno:eae6a871 INFO : kernel:lk INFO : product:QC_REFERENCE_PHONE OEM : FAILunknown command Done! Elapsed: 00:00:09 |
04-01-2019, 15:04 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | yes for that i have request read info because gionee dont have f3 model http://www.mediafire.com/file/0r3fsp...7.1.1_QFil.zip |
The Following User Says Thank You to rebainoor For This Useful Post: |
04-01-2019, 18:36 | #8 (permalink) | |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 72A2E996 ID_BLOCK_L : C58F7967EF4192FE14BD899275AF31DA ID_BLOCK_L : CE584386DB8DB36E3C3E4038152351BF Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX64MB Boot Ok! Brand : GIONEE ProdName : F6 ProdModel : GIONEE F6 Device : GIONEE_SW17G15 AndroidVer: 7.1.1 Manufact. : GIONEE SysPatch : NMF26F DevComTime: 12/5/2017 3:00:20 AM QLMxCPU : MSM8937 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:14 Reconnect Power/Cable! | |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
