Old 08-11-2015, 18:13   #1 (permalink)
Member: 1612373
Thanks Meter: 3
Angry GIONEE G4 Unknown Beseband repair done but sim 2 invalid
Try to Write Factory file , Try with ADB , Also other tool
Result same
Sim-1 Working Fine
Sim-2 Invalid
Fix Unknown BaseBand
Operation : Fix Unknown BaseBand [ v1.25 ]
User accepted FixBB operation!
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 4B00011530305538C932034D1D31F512
DA Stat : v3.2 on BBID : 0x86
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00U8
[eMMC] : FLASH_CID : 1501004B385530304D0332C912F5311D
[eMMC] : FLASH_LEN : 0x00000003A3E00000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Step #1
Step #1 ... Ok
Step #2
Step #2 ... Ok
Reset Done!
Done!
Elapsed: 00:00:29
Reconnect Power/Cable!
Repair Security
Operation : Repair Security [ v1.25 ]
Wait for phone...
Phone found! [ 31 ]
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 911404150503599
Set IMEI [01] : 911404150503607
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 31 ]
Sync...
PostCheck Ok! Repair done!
Done!
Elapsed: 00:00:33
Need Help
Old 08-11-2015, 18:48   #2 (permalink)
Member: 2082450
Thanks Meter: 1,454
Strange problem..
Did u try factory file writing???
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 08-12-2015, 04:50   #3 (permalink)
mquimpanes's Avatar
Member: 765233
Sonork: 100.1664273
Thanks Meter: 107
bro repair mode use cm2 permanent imei
Old 08-12-2015, 14:57   #4 (permalink)
Member: 1612373
Thanks Meter: 3
Originally Posted by chandanps18 View Post
Strange problem..
yes bro i try with factory file but same !
yes bro i repair cm2 permanent imei but same
waiting for support reply
bro
Rantu
Old 08-13-2015, 16:47   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. What phone says on *#06#?
Old 08-14-2015, 04:43   #6 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
try this also
Set IMEI [00] : 9114041*******
write both imei same as 1st imei
and insert single sim in slot 2 and check what it say
Old 09-09-2015, 07:29   #7 (permalink)
Member: 1757303
Thanks Meter: 3
plz help,,, how to repair 2nd imei gionee g4
Page generated in 0.20816 seconds with 9 queries
