09-15-2015, 08:47 | #1 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | gionee p3 flash not read gionee p3 not read flash file Quote:
09-15-2015, 10:07 | #4 (permalink) |
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | hi cm2 bin best work 5.0.1 lollipop to 4.4.2 downgrade ======= Flash Files set for flashing : [ MCU ] : MTK6582_1508161851.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201E225CCB69123 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201E225CCB69123 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : GIONEE ProdName : GIONEE ProdModel : P3 Device : GIONEE AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.6 ISPFF ID : 6582 , TARGET ID : 6582 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MTK6582_1508161851.bin Init Ok , Sending blocks ... Write done , 3733 blocks sent Done! Elapsed: 00:13:49 Reconnect Power/Cable! Finish at : [9/15/2015 / 2:30:40 PM] |
