Old 06-27-2015, 18:27   #1 (permalink)
Member: 69514
Thanks Meter: 65
Gionee P4 dead
How can I revive dead dead Gionee P4 ?
Here is log,
Card found: S/N
Chinese Miracle II [MTK module] v 1.21
Operation : Check / Read Info [ v1.21 ]
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 00B000B000B000B000B0000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x87
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00BC
Error : DA init Failed! Error code : 0x5
LErr : EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Old 06-27-2015, 18:53   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,596
Repair HW first - seems as FlashIC damaged.
Old 06-30-2015, 20:14   #3 (permalink)
Member: 69514
Thanks Meter: 65
I reballed flash ic ,
Now it shows like following log,Can't flsh it.
How to solve?
Card found: S/N
Wait for phone...
Phone found! [ 24 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B3758564D42017ECAD80F411D
Boot Error!
Operation Failed
Elapsed: 00:00:09
Old 06-30-2015, 21:13   #4 (permalink)
JayDi's Avatar
Member: 462970
Now - use firmware and flash phone, or if you have dump - make Init Preloader first with dump.
Old 06-30-2015, 21:34   #5 (permalink)
Member: 69514
Thanks Meter: 65
I have scatter file downloaded from moulnisky.
I can't flash it.It gives boot error.
Can I initialise preloader with scatter file?
Old 06-30-2015, 22:08   #6 (permalink)
JayDi's Avatar
Member: 462970
With Firmware flash via scatter CM2 will boot phone, if firmware support that flash ic.
Try init preloader by selecting ***preloader***.bin file from fw.
Old 07-01-2015, 09:45   #7 (permalink)
Member: 69514
Thanks Meter: 65
Getting this error for flashing as well as for int. preloader
Card found: S/N
Scatter Load Ok , BaseBand : MT6582 , Project : gionee82_cwet_kk , Storage : EMMC
Files found : 14 , Set to Flash : 13
Ready to Flash!
Operation : Flash [ v1.21 ]
======= Flash
Wait for phone...
Phone found! [ 24 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
LErr : 00000BC0
Boot Error!
Operation Failed
Elapsed: 00:00:03
Old 07-01-2015, 10:19   #8 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,974
Card found: S/N
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 24 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
LErr : 00000BC0
Boot Error!
Operation Failed
Elapsed: 00:00:03
Hello,
Try with this preloader attached, it's for Gionee P4 jellyBean.
Br.
Old 07-01-2015, 10:50   #9 (permalink)
JayDi's Avatar
Member: 462970
Yes, this one will work for sure.
Old 10-03-2016, 19:56   #10 (permalink)
Member: 2616704
Not work i also have dead gionee p4 sp tool show failed to enable dram and miracle show boot error
Old 10-04-2016, 07:36   #11 (permalink)
JayDi's Avatar
Member: 462970
Do you really think someone care about this in Infinity section?
Page generated in 0.31764 seconds with 8 queries
