08-13-2018, 10:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 395115 Status: Offline Thanks Meter: 7 | Gionee s10 flash help is there a new DA agent or any solution? Log.... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 0551 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
08-13-2018, 22:33 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | Download CM2MT2 v2.00 r4 and retry booting / identify operation. I found stock rom , you can download it here: Gionee_S10_T2089_MT6757_23062017 Be careful about flashing. If phone is booting, and can enter recovery, it's more safe to update it via sdcard. SDCard update can be downloaded from HERE p.s. If, for some reason, you still cant boot that phone, you can try with DA Files + Auth + Preloader files Test and post results. Don't rush into flashing the phone. Make all possible backups (full rom backup, nvram, nvdata, etc.) Phone can also have hardware issues. Best line is to try sdcard update first. If customer agrees that phone may not power on after flashing, then proceed with rom flashing via cable. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
08-14-2018, 08:38 | #4 (permalink) | |
Member: 395115 Status: Offline Thanks Meter: 7 | Quote:
08-14-2018, 14:27 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | I dont see any log with cm2 v2 r4 ? Try booting phone with it and post logs first. B.r. Alex
08-14-2018, 14:34 | #9 (permalink) |
Member: 395115 Status: Offline Thanks Meter: 7 | Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB VCOM (Android) (COM24) MODE : BOOTROM PORT : 24 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : Selected Auth/Cert not accepted by device! Check previous message for more info! Reconnect Power/Cable! |
08-14-2018, 14:51 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | https://mega.nz/#!4UoHRbxC!NOFJtOeFy...Ezxos1hqdtAwxk Test and post results. Try with volume buttons boot too. Loaders are from factory updater btw. B.r Alex
08-14-2018, 14:59 | #11 (permalink) |
Member: 395115 Status: Offline Thanks Meter: 7 | still same problem. authentication not accepted . . Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB VCOM (Android) (COM24) MODE : BOOTROM PORT : 24 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : Selected Auth/Cert not accepted by device! Check previous message for more info! Reconnect Power/Cable! |
08-14-2018, 15:27 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | Looks like you did nothing with provided files. Load custom da, load auth, retry process. B.r Alex
The Following User Says Thank You to Brka For This Useful Post: |
08-14-2018, 15:43 | #13 (permalink) |
Member: 395115 Status: Offline Thanks Meter: 7 | first provided files are bad or damaged. https://www.4shared.com/photo/tH90j_WHda/1_online.html but i tried with downloaded authentication "auth_sv5.auth" from other link it give me that auth error https://www.4shared.com/photo/UqdKJWC4ee/2_online.html |
08-14-2018, 17:12 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | File is not damaged, use latest winrar or 7zip. Also, other files cant be used, but exact matching loaders and auth files. If they dont work... No more ideas. B.r Alex
