10-17-2017, 16:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | Give also facility to read firmware which flash on adb mode 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 0230DAB9 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : CE36ACAA05919E89762B252AF54CC404 ID_BLOCK_L : EB9A2487881B43C0C5306552505F4972 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Micromax ProdName : KNIGHT2 ProdModel : Micromax E471 AndroidVer: 5.0.2 Manufact. : Micromax QLMxCPU : MSM8916 DevInfo : MSM8916__Micromax__Micromax__ANDR_v5.0.2__Micromax _E471__KNIGHT2 Reading Flash Content ... [Read Ok] : gpt_main0.bin Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 0230DAB9 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : CE36ACAA05919E89762B252AF54CC404 ID_BLOCK_L : EB9A2487881B43C0C5306552505F4972 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Micromax ProdName : KNIGHT2 ProdModel : Micromax E471 AndroidVer: 5.0.2 Manufact. : Micromax QLMxCPU : MSM8916 DevInfo : MSM8916__Micromax__Micromax__ANDR_v5.0.2__Micromax _E471__KNIGHT2 Reading Flash Content ... [Read Ok] : gpt_main0.bin Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! ALWAYS HANG ON AFTER READING DEVICE OK, SINCE I HAVE ONE DEAD HANDSET E471 AND IT FLASH ON ADB PORT SO I TRIED TO READ FIRMWARE BUT NOT SUCCESS, PLZ ENABLE TO READ E471 FIRMWARE OR ENABLE TO READ ALL QUALCOMM HANDSETS WHICH FLASH ON ADB PORT(IN DOS MODE). |
10-17-2017, 16:37 | #2 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | THIS IS CABLE FAULT FIRMWARE READ SUCCESSFULLY Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 0230DAB9 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : CE36ACAA05919E89762B252AF54CC404 ID_BLOCK_L : EB9A2487881B43C0C5306552505F4972 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Micromax ProdName : KNIGHT2 ProdModel : Micromax E471 AndroidVer: 5.0.2 Manufact. : Micromax QLMxCPU : MSM8916 DevInfo : MSM8916__Micromax__Micromax__ANDR_v5.0.2__Micromax _E471__KNIGHT2 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : ddr.bin [Read Ok] : NON-HLOS.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8936 / eMMC Firmware Size : 1785 MiB Done! Elapsed: 00:03:47 Reconnect Power/Cable! |
