09-25-2016, 20:57 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile M95 Fixed Firmware 100% tested If your phone sleep while flashing here is final and working solution. there are 2 states of M95 after going sleep any way. 1. Vibrate only 2. nothing .... fully dead. so for 1st option simply download given firmware and phone will get life. for 2nd option there can be 3 reasons. 1. Battery dead ( please charge battery and flash phone with given file) 2. Partitions required to reconfigured ( erase phone again with cm2spd 1.20 and flash with given firmware. 3. hardware / emmc / damage ( you know better what to do ) this is what I discovered while my expirement please correct me if you found something wrong. Download Link. https://www.facebook.com/Testedsolut...97077603839628 |
The Following 8 Users Say Thank You to Nasir Mobiles For This Useful Post: |
09-26-2016, 16:52 | #5 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | 1000% done dead and vibrate flash this file ok Quote:
thanks sharing this file my dead phone many days ok--- 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx35_sp7731geaplus_dt Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 7/3/2015 2:38:50 PM Project Ver : KOT49H 14B_test-keys Model Ext : QMobile M95 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:13 Reconnect Power/Cable! Loading : M95 v1 by Nasir Mobiles.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : M95 v1 by Nasir Mobiles FastCheck : 0x00537684CD Loading files ... File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin File : logo_540x960.bin File : fblogo_540x960.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin File : SC77xx.xml Load Ok! Operation : Flash [ v1.21 ] ======= Flash Files set for flashing : [ MCU ] : M95 v1 by Nasir Mobiles.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : M95 v1 by Nasir Mobiles File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin File : logo_540x960.bin File : fblogo_540x960.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : User decide to make whole erase [FL] : FLASH_FULL_FORMAT executing , wait ... [FL] : FLASH_FULL_FORMAT Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : sc7731g_CP0_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_Gx.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : fblogo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:04:28 Reconnect Power/Cable! | |
09-26-2016, 19:51 | #6 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | When M95 Was first Released , i read firmware that Time For version 1 is this your firmware same as mine OR you have improved or modified Firmware . Thanks!! |
09-28-2016, 14:51 | #7 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | yes this is modified fixed firmware which is read by CM2SPD. M95 v2 link updated... https://www.facebook.com/Testedsolut...98263913720997 |
The Following 3 Users Say Thank You to Nasir Mobiles For This Useful Post: |
10-14-2016, 21:16 | #9 (permalink) | |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Quote:
ho do i know its version 1 or version 2 , which file should i flash on faulty phone Version 1 Or version 2? Thanks! | |
10-14-2016, 21:54 | #10 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | look at back sticker of phone. V1 has nothing except IMEI. v2 has printed clearly V2. so very easy to identify. below is v2 example: |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
10-14-2016, 22:10 | #11 (permalink) | |
Thank you ! | |
10-15-2016, 11:30 | #13 (permalink) |
No Life Poster Join Date: May 2014
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | Operation : Format File System / Reset Settings [ v1.22 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 197 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! UserData : PART_MOUNT failed! Part Damaged! Will use Repair Mode! Cache : PART_MOUNT failed! Part Damaged! Will use Repair Mode! Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:34 Reconnect Power/Cable! set have blue display |
10-15-2016, 12:14 | #14 (permalink) |
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 197 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! Elapsed: 00:00:00 Reconnect Power/Cable! |
10-15-2016, 18:08 | #15 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | mr jaydi Please think of Qmobile M95 and Qmobile T480 no one can do as you can more than 100 hair fall in one night but Qmobile t480 still dancing on bolt LOgo |
The Following User Says Thank You to khanzada606 For This Useful Post: |
