Old 07-01-2009, 17:35   #1 (permalink)
Member: 383211
Thanks Meter: 131
lg kg 200 hung on lg logo help infinity
i format lg kg200 and also format it with "Chinese-miracle"with sub menu "MT62XX"but the problem is same.i flash it with download kg 200 firmmwar. i sent u log plz check.
formating log
COM14 [VCP0] selected
module v2.79
Device: LG-KG200
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6219:8B02:8B01]...
CPU: MT6219
detected CPU: MT6226MA
chip: 0031:A1C1:592E
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.79, database date: 28.06.09
ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1F.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1F.BIN
ver. sw 2: 7S7330SA00-001-R1F, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 36 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
whole flash chip log
module v2.79
Device: LG-KG200
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6219
status: FF
Boot Done
Initialize ...
flash: 98004900000002:FFFFFF00000000
Initialize Done
Set baud ...
115200
Set baud Done
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 41 sec
Old 07-01-2009, 20:28   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
How to fix LG KG195, KG200, KG300 freez/restart etc.:
1. Run "ChineseMiracle" software
2. Select model "MT6228 NAND"
3. Make "format" by "whole flash chip" method
Old 07-05-2009, 06:37   #3 (permalink)
Member: 383211
Thanks Meter: 131
i download kg200 firmware from suport erea and clean the kg200 board.now mobile is is on but it is on searching.how salve this searching problem
Old 07-05-2009, 09:54   #4 (permalink)
Member: 130995
http://www.infinity-box.com/wiki/ind...ot_make_a_call
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 07-06-2009, 15:21   #5 (permalink)
Member: 383211
Thanks Meter: 131
i flow ur links instraction and repair imie now lg200 ok and fine working thanks infinity support
Old 08-08-2009, 15:02   #6 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
thanks infinity good work
Old 08-21-2009, 12:55   #7 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
pakmobiles now change the imei it is 100% ok by me
lg kg 290 hang on logo? waseemshahzad Infinity-Box 2 01-21-2010 13:18
Please help G810 hung on samsung logo after direct unlock in v8.8.00 jhepoy_org UST Pro II 1 02-07-2009 09:22
KG 200 Start on LG logo Qaisar Mahmood Infinity-Box 5 06-30-2008 08:08
LG KG-200 Hang On LG Mono........... dil_PAKISTANI Infinity-Box 1 03-26-2008 18:05
Lg Kg 200 Infinity Team Attetion Plz prime_master786 Infinity-Box 1 02-20-2008 14:54
Page generated in 0.18611 seconds with 9 queries
