02-10-2008, 15:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | H688 TV phone second sim "emergency" calls i have H688 [tv phone] this is the firmware on it MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16 the problem is that the phone has 2 lines one of them is working fine, the other one is emergency calls always i formated both ffs for both MCUs i changed IMEI i made repair security area. same problem, this is the full info: Hardware version: MT6226, E02 Hardware version: MALATA26_05C_HW Software version: MAUI.05C.W06.16" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 555555555555558 how can i know the other IMEI of the phone? thanks in advance BR Mansi |
02-10-2008, 19:53 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice to write no just any number instead of IMEI, but write some valid IMEI from working set. first IMEI you can see by typing *#06# second IMEI you can see on GSM tester or connect infiniy box to CPU2 terminals and read out phone info. please, write there some Vaild IMEI number, not 55555555555555 and post result |
02-10-2008, 20:18 | #3 (permalink) |
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | unfortunately i returned the set back to the customer, but any way, i have tried to write correct IMEI [valied IMEI like 350........], for both CPU's, and i got same result, if the customer give it back to me, then i will try another time with [2nd CPU]. thank you for the help any way. BR Mansi |
02-11-2008, 21:38 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello mr. sayedhas! first, you explane what means "same problem" which sim card is not working? first or second? did you check for IMEIs? both correct? did you try to write new IMEIs to both phone parts? |
02-16-2008, 01:50 | #8 (permalink) |
Temporary banned !! Join Date: May 2005 Age: 39
Member: 148045 Status: Offline Thanks Meter: 17 | hi i have same problem frist sim emergency mode but second work fine when i try to manua search i see all network when i try to connect to sim network phone show try again later i try to flash phone wit flash from support area(flash+epprom) make repair and repair iemi also how can i write second iemi thk |
02-16-2008, 03:54 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first CPU operation you doing via pinout for CPU_a second CPU operation you doing via pinout for CPU_b i think in your case you just need to set correct (valid) IMEI for both phone parts try this and reply |
02-28-2008, 17:22 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice not to write to both parts 1 IMEI. In some countrys operator is not allowing two same IMEIs to stay in one network. I will tell more: some country operators block phones where last IMEI check digit is incorrect. that is why our soft always calculate valid last IMEI check digit |
03-17-2008, 09:09 | #13 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | How can i read second cpu, because, i read fullflash the second cpu, after downloading bootloader, phone is always on it self. may i know where is cpu2 power button? Thanks |
03-17-2008, 10:28 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! CPU 2 power button is same as CPU1. when you booting second MCU phone acts like this: 1. you press power button and hold it. 2. Phone start normaly, you can see "Insert SIM", but you still keep power button pressed! 3. after around 30seconds you will see that program detected second MCU 4. You still keep power button untill software asks to release it |
03-19-2008, 16:00 | #15 (permalink) | |
Member: 39948 Status: Offline Thanks Meter: 68 | Quote:
See this thread http:///showthread...51#post3170351 Post number 7 | |
need Pinout Nokia N200 TV phone 2 sim | virgix | Infinity-Box | 1 | 03-31-2009 21:37 |
TianXing TV C902 Dual SIM Card Phone with TV & Bluetooth - Silver | IPMART | ipmart WebShop | 0 | 11-24-2008 12:00 |
TianXing TV C902 Dual SIM Card Phone with TV & Bluetooth | IPMART | ipmart WebShop | 0 | 10-27-2008 15:50 |
PDA TV MOBILE A9000 imei second sim problem | josephic | HTC & PDA WM( With Touchscreen) | 0 | 06-07-2008 18:31 |
mpeg4 P888i second sim call hang | green bird | Infinity-Box | 4 | 04-23-2008 19:46 |
