10-04-2009, 19:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | Gsm cect v68 |
10-05-2009, 11:21 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! sorry, i did not get: Do you using pinfinder power wires to power phone? what happends if you try to power On phone? does it starts and after some time swithes off again? |
10-05-2009, 14:43 | #4 (permalink) | |
Member: 477842 Status: Offline Thanks Meter: 80 | Quote:
when phone is power on, i connect pinfinder cable to phone and phone is power off. and program dont search pinou to this phone | |
10-05-2009, 20:27 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! connect pinfinder data cable, connect power cable press "power On" button in pinfinder software and try to power On phone. what result you get? |
10-06-2009, 20:12 | #6 (permalink) | |
When I take out pinfinder L18A cable from the phone. Phone goes power on. and I see logo "like samsung logo" and phone please to insert card sim. But when i inserd sim card , phone only blinking and restart. | |
11-01-2009, 22:53 | #9 (permalink) | |
Have you got a picture of pinout in phone? like You have in Pinout Module 1.40. In ChineseMiracle pinout folder you have picture of CECT A606, GP900, did you have Pinout photo to CECT v68?? | |
11-02-2009, 17:51 | #10 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
unfortunately, we did not yet recieve pinout picture for this phone. however you still can test system connector pins for Tx/Rx voltages | |
11-02-2009, 21:14 | #11 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | IN Pinfinder, when I connect L18A pinfinde cable to power on phone, phone always power off ? maybe I have cable problem ? because I have the same result on CECT V68 and A8000 |
11-02-2009, 23:02 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! in this case you must use phone battery to power On phone and search for pinout in "CPU independent mode" this one you must set in pinfinder instead of "MT62xx automatic" http://forum.gsmhosting.com/vbb/show...3&postcount=15 |
11-04-2009, 08:00 | #13 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | when I connect cable to ground phone work on. but , pinfinder dont shows pinout , so maybe I change to L20a in program, and search again, is this maybe help ? |
11-04-2009, 19:15 | #15 (permalink) | |
Phone is ON POWER! MODE : "CPU independent mode" software version: 1.19 cable type: 1x18 (L18A) platform: CPU independent (autodetect) algorithm searching adapter at COM18... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... failed to detect pins time required: 426 sec Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") MODE : MT: MT62XX (autodetect) software version: 1.19 cable type: 1x18 (L18A) platform: MT: MT62xx (autodetect) searching adapter at COM18... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 147 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") | |
V68 Dual SIM Card Phone With TV & Bluetooth Function - Brown | IPMART | ipmart WebShop | 0 | 10-31-2008 07:40 |
V68 Dual SIM Card Phone With TV & Bluetooth Function - White | IPMART | ipmart WebShop | 0 | 10-31-2008 07:40 |
CECT i70 dual sim pinout (not cect i70 veptu) | glontz | Infinity-Box | 1 | 06-18-2008 17:46 |
hello plz help me how to made cable cect c1000 and cect n82 thanks | doodeh | Infinity-Box | 4 | 10-21-2007 19:59 |
cardinal v68 | olga | Sim Cloning and Scaning | 3 | 04-04-2002 02:46 |
