12-24-2009, 06:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Gtan N120 Unlocked!!!??? Code: COM3 [VCP4] selected module v2.99 Action: read codes unlock method: read codes Model: Gtran-N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:C341:E89C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 42 byte(s) read imei: 35552200006952 connection Ok 148 byte(s) read 156 byte(s) read Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 91911391/19193119 locked to: 100-00 Phone code: 0000 Finished, time used: 11 sec Remove/Install battery now ! Code: COM3 [VCP4] selected module v2.99 Device: Gtran-N120 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:C341:E89C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.BIN ver. sw 2: MAUI.06A.W06.44.MP.V20, 00000000 code offset: 00000000 ffs offset/size: 00E00000/001E0000 ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20__ffs_20091224-002755.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .............................................. required data found flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 1 (pass 1) .................. area 1 patch applied Ok Special operation Done ====> Write ... flash: 89881500010001:89881500000000 Write: eeprom Write Done ====> Finalization ... Finalization Done Finished, time used: 213 sec Remove/Install battery now ! Code: COM3 [VCP4] selected module v2.99 Action: read codes unlock method: read codes Model: Gtran-N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:C341:E89C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 42 byte(s) read imei: 35552200006952 connection Ok 148 byte(s) read 156 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 13 sec Remove/Install battery now ! |
12-24-2009, 10:44 | #2 (permalink) |
Crazy Poster Join Date: Nov 2009
Member: 1166583 Status: Offline Thanks Meter: 24 | 1-format your phone in saf mode 2-Turn your phone with a Wrong sim card 3-it will ask you np code then make this code from your log NP code: 91911391/19193119 don't forget to read full flash at first |
The Following User Says Thank You to freeeeman For This Useful Post: |
12-24-2009, 18:31 | #5 (permalink) |
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | I keep the same problem Code: COM3 [VCP1] selected module v2.99 Action: reset settings Model: Gtran-N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:C341:E89C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 42 byte(s) read imei: 35552200006952 connection Ok building list... done items to clear: 170 warning: wrong packet cs items cleared: 170 of 170 building list... done items remains: 0 Finished, time used: 31 sec Remove/Install battery now ! |
12-24-2009, 19:38 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @hvalero2001 Hello, We want to buy this phone for research, we will pay for phone and delivery. If you can sell this phone to us, please, contact to [email protected] or ICQ 561878718 and talk about delivery. |
12-25-2009, 09:37 | #7 (permalink) |
Member: 1166583 Status: Offline Thanks Meter: 24 | then make complete format it will work if don't work rewrite backup : C:\Archivos de programa\InfinityBox\MModule\Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs_20091224-002755.B0E.bin and make again complete format it will ask you NP code the backup you should use is the first backup should read date and time of backup (in case you perform other operations, so you will have the same backup again the only suitable is the first) and don't forgete to read full flashe at first BR |
gtran n120 unlock problem | ahmertelecom | Infinity-Box | 10 | 10-19-2009 09:47 |
Please Help, just need few flashing/unlocking answers - P520 | lomna | Samsung Flashers, Software, Firmware. | 3 | 02-03-2009 23:42 |
GTran N120 Unlock error , After flash Dual LCD | Aamir_Zia | Infinity-Box | 1 | 01-21-2009 10:38 |
unlocking LG-cg225 | cellrepairus | NSPRO | 0 | 04-30-2008 22:37 |
Unlock Gtran N120 | hvalero2001 | Infinity-Box | 2 | 04-20-2008 02:46 |
