01-23-2019, 17:05 | #1 (permalink) |
Insane Poster Join Date: Aug 2018
Member: 2855925 Status: Offline Thanks Meter: 62 | GTEL X6 MINI READ FIRMWARE done (custome da) Code: Operation : Read Firmware [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_GtelBoss.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D420331DEC879C415 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 DA : USB : HIGH-SPEED Boot done! Display ID : X6mini Patch Level : O11019 Product Info : k39t Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-02-05 Product Board : Product Brand : Gtel Product Device : Gtel_X6mini Product Manfct : Gtel Product Model : Gtel X6mini Product Name : X6mini Board Platform : mt6739 MT6739__Gtel__Gtel_X6mini__8.1.0__X6mini__ Read : preloader.bin Read : recovery.img Read : persist.img ExtSparse : Compression ratio : 100% Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : mcupmfw.img Read : nvram.bin Read : lk.bin Read : loader_ext.img Read : boot.img Read : logo.bin Read : odmdtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 31% Read : system.img ExtSparse : Compression ratio : 16% Read : cache.img Read : userdata.img FW Size : 1.38 GB Android Info saved : _Android_info.txt Scatter : MT6739_Android_scatter.txt Saved to : xxxxxMT6739__Gtel__Gtel_X6mini__8.1.0__X6mini__ Done! Elapsed: 00:01:17 |
The Following 3 Users Say Thank You to GtelBoss For This Useful Post: |
04-29-2019, 15:44 | #3 (permalink) | |
Freak Poster Join Date: Jan 2017
Member: 2673061 Status: Offline Thanks Meter: 82 | Quote:
05-02-2019, 07:25 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash or DA files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
11-10-2019, 09:14 | #6 (permalink) | |
Freak Poster Join Date: Apr 2017 Location: SA
Member: 2706332 Status: Offline Thanks Meter: 19 | Hi, Please can you Share the custom DA File Quote:
I have been looking all over the internet you seem to be the only person in possession of these DA files, your help will be greatly appreciated | |
11-10-2019, 12:48 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | If you do i litle search you will understand the Gtel mobile is an gionee mobile For that you need just select gionee brand in cm2mt2 and choise model with same mtk cpu with your Gtel model and do what you need |
The Following User Says Thank You to rebainoor For This Useful Post: |
11-10-2019, 14:54 | #8 (permalink) | |
Member: 2706332 Status: Offline Thanks Meter: 19 | Quote:
Sent from my Pixel XL using Tapatalk | |
11-10-2019, 15:27 | #10 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,103 | Try to select gionee f205 in list if existe if not try This F205 EXTRACT FOLDER & PASTE ON PATH C:\InfinityBox\CM2MT2\boot\Gionee THE OPEN INFINITY CM2 MT2 TOOL & SELECT MODEL & DO FRP. USE VOL DOWN WHILE BOOT. |
11-10-2019, 15:45 | #11 (permalink) | |
Member: 2706332 Status: Offline Thanks Meter: 19 | BROM : Selected Auth/Cert not accepted by device! Quote:
Tried while holding VOL DOWN This is also what im getting when im trying all the Gionee Models listed in the CM2MT2 either with holding down the keys or without hold the keys Code: PTFN : MediaTek USB Port (COM58) MODE : BOOTROM PORT : 58 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Gionee : F205 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 1C5FF0115D5ECA0DB7CE2992B3131296ECCB1B5BF04F0701DF9D900A4AB7DE4C BROM : SLA BROM : Selected Auth/Cert not accepted by device! Check previous message for more info! Reconnect Power/Cable! Code: PTFN : MediaTek PreLoader USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Gionee : F205 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! | |
11-10-2019, 16:09 | #12 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,103 | try this DA without press any key https://mega.nz/#!8BIhkYyS!cB7toPAbY...KPLiKdrBEJD3NE and post log operation |
11-10-2019, 16:14 | #13 (permalink) | |
Code: PTFN : MediaTek PreLoader USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO20.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100475836424D4203A69CCCD2C46F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D5EA784184B01B317ECA87DF1A092 DA : USB : HIGH-SPEED Boot done! ERR : 0xC0020004 ERR : SEC_DL_FORBIDDEN ERR : 0x00000000|0x087B64C8 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! | |
11-10-2019, 16:18 | #14 (permalink) | |
Member: 231728 Status: Offline Thanks Meter: 2,103 | Quote:
you can use memory tool to erase your frp partition | |
11-10-2019, 16:29 | #15 (permalink) | |
Member: 2706332 Status: Offline Thanks Meter: 19 | Now able to read the firmware Quote:
Thank you so much!!! I was able to read the firmware I'm not aware of the memory tool you mentioned above but i just want to reset the lock screen(Pin) so if i flash flash userdata.img(from the read FW) will that help me remove the lock screen? | |
