04-18-2008, 16:54 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: GUJARAT.INDIA
Member: 205176 Status: Offline Thanks Meter: 19 | Gtmobile Tv-100 V800_PCB04_GPRS_MT6228_S02.L4A2H01_6_3_1_0T01M0622 _M401.BIN phone is only at startup logo whith read full flash this message backup_nand_probably_damaged_[V800_PCB04_GPRS_MT6228_S02.L4A2H01_6_3_1_0T01M0622 _M401.BIN]_firmware_20080405-133228.B4M.bin ] when i write this flash file from support area lcd is not com properly V800_PCB04_GPRS_MT6228_S02.L4A4202_6_3_1_0T01M0608 _M401_128m_En_Ru_Cn.B4M.bin please anyone have upload this flashfile |
04-19-2008, 08:18 | #3 (permalink) |
Member: 205176 Status: Offline Thanks Meter: 19 | yes i tried to make format but this error here is log COM1 [VCP0] selected Action: reset settings Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 32 sec COM1 [VCP0] selected Action: reset settings Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 62 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM1 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: V800_PCB04_GPRS_MT6228_S02.L4A2H01_6_3_1_0T01M0622 _M401.BIN ver. sw2: L4A2H01.6.3.1.0T01M0622_M401, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation Initialize bootcode Done Check firmware integrity... Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... formatting... .....................error: code: 4200006900 .................................................. ........error: code: B200006900 .................error: code: BE00006900 ....error: code: A502000000 error: code: 0600000000 Backup required data Fail Finished, time used: 94 sec Remove/Install battery now ! |
need arabic flash file for tv 100 | sayedhas | SpiderMan | 2 | 12-24-2008 10:06 |
Tv 100 flash wrİte problemmm | zidann | Chinese Models & Cloned Phones | 3 | 10-18-2008 13:58 |
please help with TV 100 memory card problem | hmmm... | Chinese Models & Cloned Phones | 3 | 09-19-2008 01:51 |
succes format SPD TV 100 SC6600M/R | titan_wonder | SpiderMan | 0 | 08-24-2008 10:25 |
Tv 100 | Nabil3H | Infinity-Box | 3 | 07-03-2008 14:34 |
