12-11-2007, 14:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: bulgaria,plovdiv Age: 53
Member: 62866 Status: Offline Thanks Meter: 49 | Gtran N120 Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6227, E02 Hardware version: J2_MAIN_Rev02 Software version: MAUI.06A.W06.44.MP.V Software date: 2005.04.12 Barcode: KT_GDP8 imei: 355522000414072 Finished, time used: 4 sec Power off phone now ! |
12-13-2007, 10:33 | #3 (permalink) | |
Member: 62866 Status: Offline Thanks Meter: 49 | Quote:
usb pinouts are keyboard up / 1 2 3 4 5 6\ 7 8 9 10 11 12 1 and 7 are data in/out 3 and 9 are + 2 is gnd can you help me to find right pinout ?? br Last edited by stefan_162; 12-13-2007 at 10:43. | |
12-13-2007, 11:32 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Please, try this Rx/Tc pinout for flash reading (if no connection swap Rx/Tx wires) 1: 2: Gnd 3: +Vcc 4: 5: Tx 6: USB D- 7: 8: 9: +Vcc 10: 11: Rx 12: USB D+ Waiting for your results. |
12-13-2007, 11:51 | #6 (permalink) | |
pinout is right COM4 [Serial2] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 detecting structure #2... done imei: 35552200041407 connection Ok detecting structure #1... done Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 91911391/19193119 locked to: 100-00 Phone code: 0000 Finished, time used: 9 sec Remove/Install battery now ! how to enter unlock code i have read full flash if you need i can send you with standart method unlock phone is still locked br | |
12-13-2007, 12:20 | #7 (permalink) |
Member: 62866 Status: Offline Thanks Meter: 49 | COM4 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw2: MAUI.06A.W06.44.MP.V20 ffs offset/size: 00E00000/001E0000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 89881500010001:89881500000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. . detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok flash: 89881500010001:89881500000000 Identification Done Manipulation... .................................................. . lock area found Manipulation Done Finalization... Finalization Done Write... flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: lock-area-1 Write Done Finished, time used: 92 sec Remove/Install battery now ! phone is still locked |
12-13-2007, 13:35 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @stefan_162 please, send "backup_flash..." files to [email protected] also pls send "backup_system_log..." files (if exists), it's important how to unlock: insert wrong SIM and enter NP code. If phone don't ask NP code you need to make "smart safe" unlock method (it's similar to code reading, but code will be entered in phone automatically via software) waiting for your results |
12-13-2007, 15:05 | #9 (permalink) | |
Action: unlock unlock method: smart fast Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 detecting structure #2... done imei: 35552200041407 connection Ok detecting structure #1... done Finished, time used: 29 sec Remove/Install battery now ! phone is still locked i have send to you backup and log wait for some result br | |
12-13-2007, 15:52 | #11 (permalink) | |
COM4 [Serial2] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 detecting structure #2... done imei: 35552200041407 connection Ok detecting structure #1... done Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 91911391/19193119 locked to: 100-00 Phone code: 0000 Finished, time used: 14 sec Remove/Install battery now ! br | |
12-13-2007, 18:02 | #13 (permalink) | |
==== log opened: [13.12.2007 г. 18:32:40] ==== Application: D:\Documents and Settings\stefan\Desktop\MModule\MModule.exe Loading data, wait... [Infinity Box] v1.72 Wait... Device: Aiko 17G Done Device: Gtran N120 COM1 [Serial0] selected Action: unlock unlock method: smart fast Model: Gtran N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide Operation failed ! Finished, time used: 19 sec Remove/Install battery now ! COM4 ready COM4 [Serial2] selected Action: unlock unlock method: smart fast Model: Gtran N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 42 byte(s) read imei: 35552200041407 connection Ok 148 byte(s) read reading data... building new data... writing data... done Finished, time used: 14 sec Remove/Install battery now ! COM4 [Serial2] selected Device: Gtran N120 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Identification... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw2: MAUI.06A.W06.44.MP.V20 ffs offset/size: 00E00000/001E0000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]]... file saved: D:\Documents and Settings\stefan\Desktop\MModule\backup_eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]_20071213-183709.B0E.bin flash: 89881500010001:89881500000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... detecting additional parameters... .............................................. flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 .................. additional parameters detected Ok Finalization Done Write... flash: 89881500010001:89881500000000 Write: eeprom Write Done Finished, time used: 196 sec Remove/Install battery now ! COM4 [Serial2] selected Action: read codes unlock method: read codes Model: Gtran N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 42 byte(s) read imei: 35552200041407 connection Ok 148 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 91911391/19193119 Phone code: 0000 ==== log opened: [13.12.2007 г. 18:50:38] ==== Application: D:\Documents and Settings\stefan\Desktop\MModule\MModule.exe Loading data, wait... [Infinity Box] v1.72 Wait... Device: Aiko 17G Done Loading file v.02... Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20_En_Es_ver2.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw2: MAUI.06A.W06.44.MP.V20 Languages: En Es Device: Gtran N120 COM4 ready Loading file v.02... Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20_En_Es_ver2.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw2: MAUI.06A.W06.44.MP.V20 Languages: En Es COM4 [Serial2] selected Device: Gtran N120 Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Identification... reading [eeprom]... file saved: D:\Documents and Settings\stefan\Desktop\MModule\backup_eeprom_2007 1213-185337.B0E.bin Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: 89881500010001:89881500000000 Write: Firmware Write Done Finished, time used: 94 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM4 [Serial2] selected Device: Gtran N120 Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6227:8A02:8A01]... chip: 0031:21C1:BB2E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Identification... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw2: MAUI.06A.W06.44.MP.V20 ffs offset/size: 00E00000/001E0000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]]... file saved: D:\Documents and Settings\stefan\Desktop\MModule\backup_eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]_20071213-185539.B0E.bin flash: 89881500010001:89881500000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 89881500010001:89881500000000 Write Done Finished, time used: 92 sec Remove/Install battery now ! this is operatin log still no result phone is locked | |
Gtran N120 no unlock | ricardo ariza a | Infinity-Box | 17 | 11-26-2010 17:54 |
gtran n120 unlock problem | ahmertelecom | Infinity-Box | 10 | 10-19-2009 09:47 |
Gtran N120 Pinout | pr1mux | Infinity-Box | 10 | 06-30-2009 06:03 |
gtran n120 I could not unlock the phone | manuelalejandro | Infinity-Box | 1 | 05-30-2008 07:33 |
Unlock Gtran N120 | hvalero2001 | Infinity-Box | 2 | 04-20-2008 02:46 |
