11-16-2008, 21:18 | #1 (permalink) |
Junior Member Join Date: Feb 2004 Location: Hungary Age: 48
Member: 54500 Status: Offline Thanks Meter: 1 | ***** G629 socket to Infinity box How let me do it? I do not have a socket to it, only a factory usb cable. Please help Infinity Support. |
11-17-2008, 12:06 | #5 (permalink) |
Member: 54500 Status: Offline Thanks Meter: 1 | "Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3803:0004 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01" NO reading FULL FLASH! What is it necessary to put in another place? |
11-17-2008, 12:35 | #6 (permalink) |
Member: 54500 Status: Offline Thanks Meter: 1 | READ GENERAL INFORMATION : Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: M1234525_GEMINI_HW Software version: MAUI.GEMINI.W08.12" Software date: 2006.06.14 Barcode: GC629G_S09178033E 10 imei: 354752010000792 imei: 135790246811220 Finished, time used: 7 sec Power off phone now ! |
11-17-2008, 16:28 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @GSMagic As I can see you have found the pinout and you can connect phone with software. What is the problem now ? I do not see any errors in log, I see only truncated log text. Please, make detailed problem description so we will be able to understand how to help you. |
11-17-2008, 16:53 | #9 (permalink) |
Member: 54500 Status: Offline Thanks Meter: 1 | ==== log: [2008.11.17. 16:48:01] ==== COM5 selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3803:0004 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN ver. sw 2: MAUI.GEMINI.W08.12, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00710000 Detected eeprom/ffs address is non-standard: 00710000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00710000 detecting eeprom/ffs size... eeprom/ffs size: 008F0000 ffs chip: 00 eeprom/ffs area: 00000000:00710000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]... warning: wrong data size at 0x00001C00, retry... read error recovered warning: wrong data size at 0x00007400, retry... read error recovered warning: wrong data size at 0x0000C800, retry... read error recovered file saved: D:\Program Files\InfinityBox\ChineseMiracle\flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]_20081117-164854.B0M.bin Finished, time used: 36 sec Remove/Install battery now |
11-17-2008, 18:45 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Please, explain what is the problem ! As I can see from log backup was done and file was saved: D:\Program Files\InfinityBox\ChineseMiracle\flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]_20081117-164854.B0M.bin So, what is the problem, we need to know more information ! Also, what cable you have used ? |
11-17-2008, 18:46 | #12 (permalink) |
11-17-2008, 22:14 | #13 (permalink) |
Member: 54500 Status: Offline Thanks Meter: 1 | reading: flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]... warning: wrong data size at 0x00001C00, retry... read error recovered warning: wrong data size at 0x00007400, retry... read error recovered !!!!!!!!!!!!!!!! He cannot read the content. 0 bytes are the rescued data. The cable is perfect. The log a file implies the mistake. Somebody else has a problem like this on the internet. But we the trouble? The Infinity-box Chinese Miracle.exe does not know this telephone??? |
11-17-2008, 22:57 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Man... I become little bit angry because you have ignored my questions. Infinity-Box is The best software for this kind of phones, if phone can be booted (in your case it was) this means that Infinity-Box know this model and can repair it ! If you unable to use software well you must read documentation and ask advices from experienced users and programmers ! My question again: What cable you have used ? I ask you about this because many Chinese zero-quality factories produce now zero-quality cables based on Prolific chip, and many greedy people buy this kind of cheap crap, as a result in many cases this kind of cables can not be used well with high-quality software and as a result many "zero quality cable lovers" start to talk about bugs in our software, but in fact all problems is a result of "saved money" and low-quality cables ! Do you understand now why you must make an answer or easy question ? |
11-17-2008, 23:14 | #15 (permalink) |
Member: 54500 Status: Offline Thanks Meter: 1 | Your answer was big strong one. I did nearly 150 pieces of telephone Infinity box. Infinity Plus,Pinfinder adaptor, RJ45 cable and the cable soldering the telephone is for inside. I write a Hungarian and Slovak language into it,with full translation. Maximally in detail. I did all of the telephones until now with these cables. All the best quality cable,that the you I bought from resellers. For example GSMSERVER.COM. I am sorry for it if you look at this much for unfortunate one. Indulgence, that I asked altogether. |
Infinity-Box Serial Number (S/N) is your key to Infinity-Box support... | .:Mahmoud El-masy:. | Infinity-Box | 29 | 10-28-2012 10:42 |
to infinity box, new flash file not in support area, i uploaded it to mediafire | KhalIman | Infinity-Box | 1 | 03-13-2010 21:16 |
to infinity-box team | hevernage | Infinity-Box | 1 | 06-20-2005 21:38 |
UPDATE: 05 MAY 2005. Nec-E101 Support added to Infinity Box | Infinity-Box | Infinity-Box | 9 | 05-05-2005 21:54 |
NEC E101 Direct Unlock Solution added to Infinity Box | Infinity-Box | NEC | 9 | 05-05-2005 19:23 |
