02-16-2008, 23:35
#1 (permalink)
Member: 678782
Thanks Meter: 0 | Guide ME for Cect t689 flash & format ok but cant power on hello infinity team
another CECT-T689 2sim with 1*18 connector dont power on BUT it can flash & format safe/complete completly.
i flashed with all flash files & eeprom in support becuase i dont know maybe it flashed with any version
this mtk-box is verry bad problem
this it a log flash whit a flash file & format log Quote:
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 003162E:6CD4
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9604BD06.[E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1.BIN_ED8D 585B].rpl
identification#1 detection finished
device-id: 9604BD06
identification#1 protocol ver: 04
ver. sw1: E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E550_A5FRENCHBT.01.1, A4A77212
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00800000
ffs chip: 00
eeprom/ffs area: 00000000:00800000-00FFFFFF
reading [eeprom[E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1.BIN]_20080217-004327.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
security area#1 calculation...
done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _9604BD06_E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_ 1.BIN_ED8D585B_20080217-004537.B0X.bin
Area: Firmware
Write: Firmware
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _9604BD06_E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_ 1.BIN_ED8D585B_20080217-011137.B0X.bin
Finished, time used: 3417 sec
Remove/Install battery now !
| and another Flash file Quote:
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
19200
Connecting, wait...
CPU: MT6226
chip: 003162E:6CD4
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9604BD06.[E550_A5FRENCHBT_E550_GPRS_MT6226_S01.V3_0_01_3.BIN _8C001A0A].rpl
device-id: 9604BD06
ver. sw1: E550_A5FRENCHBT_E550_GPRS_MT6226_S01.V3_0_01_3.BIN
ver. sw2: E550_A5FRENCHBT.V3_0.01.3, F5E5FF73
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom[E550_A5FRENCHBT_E550_GPRS_MT6226_S01.V3_0_01_3.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E550_A5FRENCHBT_E550_GPRS_MT6226_S01.V3_0_01_3.BIN]_20080217-012614.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _9604BD06_E550_A5FRENCHBT_E550_GPRS_MT6226_S01.V3_ 0_01_3.BIN_8C001A0A_20080217-012712.B0X.bin
Area: Firmware
Write: Firmware
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _9604BD06_E550_A5FRENCHBT_E550_GPRS_MT6226_S01.V3_ 0_01_3.BIN_8C001A0A_20080217-012738.B0X.bin
Finished, time used: 429 sec
| tested all flash files in support
tested hold power key for 40 - 60 sec but do not power on phone
this is verry urgency |
