haier c2030 how to unlock hi please tell me how to unlock haier c2030. i try but not done. please solve this problam thanks. |
Could U Please Post Logs ????? As I Can't read Ur Mind What U Have Done To Unlock this Model??? So Waiting For Logs Wbr <<<MEGATRON>>> |
how to unlock tell me the produce |
Connect phone through v3 cable install proper drivers (u can download from support) after That open cdma tool select proper port select model and press SPUNLOCK wait fe seconds and Ur phone unlocked WBR <<<Megatron>>> |
c2030 hang and switch off when using (utl nepal) rim card. please tell me the soluion. thanks |
Hang On Perticuler uim card??? may b different uim card 64k? U Can Try To Flash fone in Emergency Call+Pwr (Flash File And Flasher Already On Support ) After That Perform Unlock Operation Again Hope Ur Problem Will Be Solved Wbr <<<MEGATRON>>> |
not solved. i face same problam in huawei c5005. i do factory reset by code. then problam solved in huawei c5005. but now same problam in haier c2030. problam with only (utl nepal) uim card. other card is working well. please solve this... thanks |
i flash phone and now its (invalid card) then try to unlock via ininity cdma. log is here COM2 [QCUSB_COM2_2] selected module v1.14 Device: Haier-C2030 Action: read/check information Phone should be Switched ON ! connecting... wait conecting... wait conecting... wait conecting... wait conecting... wait conecting... wait conecting... wait conecting... wait conecting... not conected... Finished, time used: 12 sec what is this problam |
when i click spunlock. it says COM2 [QCUSB_COM2_2] selected module v1.14 Device: Haier-C2000 Action: "sp-unlock" Phone should be Switched ON ! connecting... checking version... A2030MT04your phone version not supported yet or try again.. Finished, time used: 5 sec |
Ur Model A2030MT04 And you are selecting c2000 device to unlock c2030???? select proper model before unlock wbr <<<MEGATRON>>> |
i do same and it says COM2 [QCUSB_COM2_2] selected module v1.14 Device: Haier-C2030 Action: "sp-unlock" Phone should be Switched ON ! connecting... checking version... HA2030MT04 Haier C2030 version 04 selected.. Sending command... pacthing in progress... Finished, time used: 19 sec |
set is unlocked but same problam with (utl nepal) card. please tell me other solution. i have 14 units pending. thanks |
no replay??? infinity has no solution of my problam??? please repley infinity team. thanks |
Check Tata Reliance Mts Vergin Sky Telecom etc If They Are Working Its Not Unlocking Problem May B Diffrent UTL Crad Introduced Check Old UTL Card Wether It Works Or Not http://forum.gsmhosting.com/vbb/f633...30#post6047984 Wbr <<<MEGATRON>>> |
