02-29-2008, 15:26 | #1 (permalink) |
Registered User Join Date: Aug 2004 Age: 54
Member: 76533 Status: Offline Thanks Meter: 8 | problem in Flash n82 I have a problem in Flash n82 Work addresses and telephone was working OM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80229-151951.B0E.bin flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 01227E22022201:18E59F00000000 Write Done Finished, time used: 167 sec Remove/Install battery now ! |
02-29-2008, 22:50 | #3 (permalink) |
Member: 76533 Status: Offline Thanks Meter: 8 | [QUOTE=InfinityHelp;3123075]hello! log file looks good. what problem you are facing? And why you formating Second MCU part (MCU_b)? Thank you he telephone does [rwstaar] and uncles of people in format of the telephone pressures on the button until the telephone flames lacs format does maybe worth to focus on first MCU |
problem in flashing k790i in cuiser | M.YASIR | Cruiser Suite | 3 | 04-30-2007 09:41 |
Problem in flashing 7650 with griffin! | chinex14 | Griffin | 11 | 10-04-2003 02:36 |
Problem in flash reading 000122da 5110? | FunLog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-06-2001 09:28 |
