06-13-2016, 20:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | <<<HaieR W717 Imei RepaiR & MaKe ScaTTeR>>> MT6572 ((This post is for educational purposes only)) READ INFO Code: Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 45010053454D3034473A53F376EA912D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473A53F376EA912D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xF110592FB5A868CBA2CDC0A1C0807FEC INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Haier ProdName : W717 ProdModel : W717 Device : W717 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : HW-W717-H01-S003-ES SECURITY : IMEI_SW [1] : 866317020xxxxxx IMEI_SW [2] : 353919025xxxxxx BTMAC Addr : 0007A8890A23 WiFi MAC : 0007A8990352 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P5_1_wg_n EXTRA : LCD [0] : ili9806e_wvga_dsi_vdo_zgd_m08 LCD [1] : ili9806e_wvga_dsi_vdo_jingtai LCD [2] : #ili9806e_wvga_dsi_vdo LCD [3] : LCD [4] : nt35510_dsi_cmd_6572 LCD [5] : ili9806e_wvga_dsi_vdo_jingtai LCD Res : 800x480 TOUCH [0] : ft6206_yuye TOUCH [1] : GT9XX_hotknot CAM [0] : gc2145_mipi_yuv_riduo CAM [1] : hi541_mipi_yuv_m08 CAM [2] : sp0a19_yuv CAM [3] : gc0312_yuv_riduo CAM [4] : sp2529_mipi_yuv CAM [5] : gs5604_mipi_yuv#s5k4ecgx_mipi_yuv CAM [6] : #s5k8aayx_yuv MODEM : huiyue72_w_kk_hspa_b2b5 LOCALE : es_ES ru_RU en_US en_GB ar_EG fr_FR in_ID ur_PK vi_VN zh_CN zh_TW it_IT hi_IN tl_PH de_DE pl_PL pt_BR pt_PT nl_NL ro_RO tr_TR REPAIR IMEI ((Permanent)) Code: Boot Ok! IMEI [00] : 866317020XXXXX IMEI [01] : 35391902XXXXXX IMEI [02] : 35391902XXXXXX IMEI [03] : 35391902XXXXXX Set IMEI [00] : 8663113208XXXX Prepare finished. Security check required! Wait for phone... Phone found! [ 15 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just re-insert cable) on this step Reconnect Power/Cable! MAKE SCATTER ((REAL)) Code: Reading Flash Content now ... Brand : Haier ProdName : W717 ProdModel : W717 Device : W717 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : HW-W717-H01-S003-ES [Read Ok] : preloader_m08_haier_b2b5_single_es.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / m08_haier_b2b5_single_es / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 749 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__Haier__W717__W717__4.4.2__HW-W717-H01-S003-ES\ All done! Do You WANT more.....???? >>MaO<< |
