Old 01-14-2008, 21:32   #1 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
hantel HT6600 pinout needed
I stil finding pinout of 泰hantel HT6600. http://www.nftx.com.cn/more_pic.asp?ProdId=0177.
if someone ready found it plz share to me.
Thanks
Old 01-15-2008, 00:37   #2 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
Now I tried by myself here log:
COM10 [Serial2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
chip: 0001:4803:000F
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
error: wrong answer[BB]
error: can't work at this speed, use lower speed
Set baud Fail
Finished, time used: 11 sec
Remove/Install battery now !
what is problem ?
Old 01-15-2008, 15:49   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Hello,
Probably you need to use 115200 baud.
Please, post here pinout for this phone.
Old 01-15-2008, 16:00   #4 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
only slow with pl2303 working. I have move phone locked code successfull but afterthat phone no network.
COM11 [Serial2] selected
Action: user code
unlock method: standard
Boot...
19200
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: SIMC25_06B_PCB01_GPRS_MT6225_S00.MSG52-1V01_01B02.BIN
ver. sw2: MSG52-1v01.01b02
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
reading [eeprom[SIMC25_06B_PCB01_GPRS_MT6225_S00.MSG52-1V01_01B02.BIN]]...
file saved: C:\Program
Files\InfinityBox\ChineseMiracle\backup_eeprom[SIMC25_06B_PCB01_GPRS_MT6225_S00.MSG52-1V01_01B02.BIN]_20080115-212644.B0E.bin
Identification Done
Manipulation...
detection procedure, wait...
detection procedure completed
Manipulation Done
Finalization...
Finalization Done
Write...
Write: eeprom
Write Done
Finished, time used: 961 sec
Old 01-15-2008, 19:08   #5 (permalink)
Member: 130995
Hello,
How to fix PL2303 problems: http:///vbb/showthread.php?t=489702
No network: did you tested phone before unlock regarding network ?
You can try to restore eeprom backup, phone will be locked back but you can test phone network.
Also, you can try to use "code reading" unlock method.
hantel k1 pinout needs vaghubha_sodha SpiderMan 0 01-16-2010 09:26
hantel M2210 pinout needed kasim Infinity-Box 2 07-14-2008 13:39
Need Hantel Ht6088 Pinout himanshu taldar Infinity-Box 7 06-09-2008 11:21
Hantel HT5100 Pinout Found !!!! phisi Chinese Cocktail 1 05-05-2008 09:41
Hantel Ht5100 Pinout Helo Please phisi Chinese Cocktail 4 05-05-2008 08:56
Page generated in 0.25755 seconds with 8 queries
