Old 01-31-2008, 09:22   #1 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
china screen white
china mobile after format with infinity screen white phone work proper but white display i dont have eeprom back up what can i do plz help infinity team
Old 01-31-2008, 10:28   #2 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
what was the phone problem before format ???
in case it was white screen and u flash it for this problem and still the same then it is a hardware problem
Old 01-31-2008, 10:45   #3 (permalink)
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
phone on restart when i insert sim after format phone when software ask you make epprom backup i click no complete phone format and phone on white display
Old 01-31-2008, 11:03   #4 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
there are some eprom files on support site so u can check if u can find any eprom file for the software version was on your phone and try to reflash it to your phone again and see what happen
in case u can not find same eprom u can look for any other working phone which has the same model like the one u have and read eprom of it and flash your phone with and see what could happen after that
good luck for u
Old 01-31-2008, 11:13   #5 (permalink)
traxgsm's Avatar
Member: 636518
Thanks Meter: 175
what is the phone (anycool ??)
Old 01-31-2008, 17:04   #6 (permalink)
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
phone was mpeg4 non brand china no sticker in back i try all epprom but not sucess
Old 02-01-2008, 01:42   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
post here formating log. we will check original software version and also if there was really not saved backup
Old 02-01-2008, 12:05   #8 (permalink)
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
Do you want to continue ?
COM3 [Serial2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6219:8B02:8B01]...
CPU: MT6219
CPU: MT6226MA detected
chip: 0031:CF41:AC0C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: E728_PCB01_GPRS_MT6226_S01.M22M019B0601_5_3_1_5D05 22C08.BIN
ver. sw2: M22M019B0601.5.3.1.5D0522C08, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
Finished, time used: 34 sec
Remove/Install battery now !
Old 02-01-2008, 12:19   #9 (permalink)
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
http://rapidshare.com/files/88019314...39554.zip.html firmware and epprom back up here plz infinity team help me
Old 02-02-2008, 18:05   #10 (permalink)
Member: 148515
hello!
no such flash file version in our collection.
Please find same phone and read out working dump
this is the only solution for the moment
Old 03-18-2008, 10:07   #11 (permalink)
Member: 19411
can somebody upload repair eeprom for this:
E553_X9TRPAF5C_E553_GPRS_MT6226_S01.V23_01_1.BIN
TIA
Old 03-18-2008, 11:06   #12 (permalink)
Member: 148515
hello mr. brabbsss!
we have flash file for this phone on our support site.
why do you need eeprom file? Just make complete format FFS and phone itself will rebuild eeprom to original state
dont forget to restore IMEI after this
Old 03-18-2008, 12:45   #13 (permalink)
Member: 19411
Thank you infityhelp...
Old 01-10-2009, 09:11   #14 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Action: reset
Boot...
19200
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
ffs chip: 00
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
i have same problem with same set ,
if anyone have this flash plz share thanks
Old 01-10-2009, 18:35   #15 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If this file can not be found in support area (use "search" in support area first)
it will be good if somebody can read full flash from the same good working phone and send
full flash backup to [email protected] so we will be able to prepare and upload
good working files in support area for all users.
p.s.
request to everybody:
1. Please never ask support person to send any files via e-mail or any other way.
2. Please, do NOT send to us backup files from damaged phones. We can NOT repair damaged files !
3. All files that we have already uploaded in support area, we do NOT have any other files.
4. All files that we have already uploaded in support area and all users can download files easily from support area.
The Following User Says Thank You to InfinitySupport For This Useful Post:
china 6300 white display saqi160 Chinese Models & Cloned Phones 5 06-25-2010 22:20
china 6303 white screen i chang lcd but white screen shani72 Chinese Models & Cloned Phones 1 02-21-2010 17:28
Samsung D410 Screen White JulesJ Samsung Hardware Repair 12 03-20-2007 16:16
d410 screen white gbada Samsung Hardware Repair 25 09-25-2006 13:29
X70 screen white Cat10 Panasonic 1 10-06-2004 09:12
Page generated in 0.25428 seconds with 9 queries
