11-21-2007, 18:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | Has Any Unlocked a Fly SLT100?? Has any managed to unlock one? Or know where i can purchase a working cable. Be |
11-27-2007, 01:07 | #6 (permalink) |
Member: 104911 Status: Offline Thanks Meter: 42 | i have tried both ways 1-18 and 18-1 (pins 6<>7(rx/tx) and 14(gnd)) from original and kg800 connector but its does not work hence the thread. the phone either turns on or does nothing(not turn on). br |
11-27-2007, 01:10 | #7 (permalink) | |
if phone not turns on when you have "unlock" button pressed this means that pinout is correct. You need to hold phone power button pressed more long time. | |
11-27-2007, 01:11 | #8 (permalink) | |
Member: 104911 Status: Offline Thanks Meter: 42 | Quote:
hi m8, i had to buy the phone from Argos just to get the original USB cable but the pins used are different to the pinout from support (and it has the small pcb board inside like the flysl600 cable has), only the used pins are filled in not the ones we need. btw, connector is the same as kg800 (lg chocolate). br | |
11-27-2007, 01:14 | #9 (permalink) | |
br | |
11-27-2007, 22:44 | #11 (permalink) | |
right, i have made the correct cable now (your pinout is the wrong way around, should be keyboard down not up). made the cable out of kg800 cable. i still have a problem with the unlocking though, when i "read codes" where are the codes shown? when i use "smart unlock" the phone still asks for "np code" although the softwhere shows "netlock" off, and all other locks off. br | |
11-27-2007, 22:54 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Codes should be shown in main lof window below lock status. Please, post log here during both operations or send "operation.log" file from "MModule" folder to [email protected] |
11-27-2007, 23:02 | #13 (permalink) |
Member: 104911 Status: Offline Thanks Meter: 42 | this is what i get: COM4 [VCP1] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02:8A02]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: MAUI.06A.W06.36.MP.V36 Version: EZIO28_06A_HW imei: 35820901013378 connection Ok Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 37 sec Remove/Install battery now ! btw, i have one try left so need the correct code now, br |
11-27-2007, 23:48 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @James-R is it really Fly-SLT100 or other model but similar to SLT100 ? Anyway, please, make "read firmware" operation (only firmware due to full backup will be about 100Mb) and send file to [email protected] I'll check it ASAP. Also, if after flash reading you will see in folder with software new files like "backup_system_log...", please, send it too. |
11-27-2007, 23:55 | #15 (permalink) | |
br | |
plz help me unlock my fly slt100 ,phone says enter np code | ARAB GSM | Infinity-Box | 8 | 09-15-2010 01:03 |
how to unlock FLY slt100 | khaleefa | Infinity-Box | 9 | 06-02-2010 13:03 |
can i Unlock FLY SLT100 with Infinity ? | .:Morpheus:. | Infinity-Box | 33 | 11-17-2008 10:30 |
how to unlock fly SLT100 ? | the_frightener | Infinity-Box | 38 | 07-15-2008 16:09 |
Unlock Fly Slt100 | Mansoor | Infinity-Box | 4 | 04-09-2008 14:53 |
