08-11-2015, 22:53 | #1 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | have error for any operation i have error(attached) for any operation for many mtk model like G610-G700-G730-etc i did test on full working phone(just for test)....But still have error Quote:
08-12-2015, 02:48 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | First try without pressing any boot key. If not solve then, Looks like phone has secured boot or bootloader locked.. If bootloader locked, then try unlock it and then check... Br Last edited by chandanps18; 08-12-2015 at 02:55. |
The Following 2 Users Say Thank You to chandanps18 For This Useful Post: |
08-12-2015, 09:01 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Select Huawei Secured G610/Y330 from model list selection in Settings tab under Cpu/Workmode SP:Select Model [6571..6795] and then try. BTW we are trying to add more models. Br. | |
08-12-2015, 09:22 | #4 (permalink) | |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,073 | Quote:
Select Huawei Secured G610/Y330 from model list selection Code: Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending Error : DA init Failed! Error code : 0x2 Boot Error! Operation Failed Elapsed: 00:00:37 Reconnect Power/Cable! | |
08-12-2015, 12:56 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi So,We can do nothing for many of secured models like G610-H30-G700-G730_etc? Reset Pattern or Repair Imei or Read/Write Factory FW or Binary is very OLD Option...How That is possible Infinity not supported those operation for secured phone? Can u add unlock bootloader directly ? |
08-13-2015, 16:53 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Unlock - no reason, it secured chip by itself. Service - due their "specific" model - too hard make much operations. Problem not in process, problem in samples in my region. When I found 5-7 pcs of different models - things will goes easy. To hard do anything safe,correct,stable with 2 phones, which I added - G610-U01 and Y330-U01. |
