03-02-2010, 11:49 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: ? Age: 57
Member: 1198691 Status: Offline Sonork: 1589060 Thanks Meter: 148 | Kp170 Guide about unlock Code: COM7 selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 350300000000001 file saved: J:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20091217-121221.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 350300000000001 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 98 sec Remove/Install battery now ! After this Flash with KP170_eeprom_calibration_04.B1E.rar your phone will be unlocked. |
The Following User Says Thank You to MR 100% For This Useful Post: |
03-16-2010, 17:40 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | procedure to unlok KP 170 with infinity success 100/100 already posted procedure to unlok KP 170 with infinity success 100/100 |
To all about unlock t156 new v guide and logs | /\/\A/\/| | Infinity-Box | 18 | 12-09-2009 20:35 |
Information & guide about hacking | javish | Off Topic Zone | 0 | 12-29-2008 20:05 |
<<<full guide about flash and unlock cid49 etc>>> | GUDO-GSM | Cruiser Suite | 10 | 12-17-2008 17:27 |
Any One Plz Give me guide about this | gsm-fault | Sim Cloning and Scaning | 1 | 02-20-2008 23:16 |
User guide about damaged/blocked/killed Infinity-Box dongles | InfinitySupport | Infinity-Box | 5 | 01-01-2008 18:47 |
