Old 12-13-2009, 06:43   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Heare is simoco sm-324 new firmware detected
HEARE IS SIMOCO SM-324 NEW FIRMWARE DETECTED
HEARE IS FULLOK SET LOG:-
COM6 [VCP0] selected
module  v3.02
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:B716:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98009600000000:2BEA0000000000
flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.9F8FAE10.[C500MK_PCB01_GPRS_MT6223P_S00.SIMOCO_SM234_V1_00_02.BIN_04978024].rpl
New firmware detected (v.3.02, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 9F8FAE10
rom info protocol ver: 04
ver. sw 1: C500MK_PCB01_GPRS_MT6223P_S00.SIMOCO_SM234_V1_00_02.BIN
ver. sw 2: SIMOCO_SM234_V1.00.02, 24809704
code offset: 00000000
ffs offset/size: 00730000/000D0000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00730000
checking area [00000000]: 00080000-007FFFFF...
ffs/eeprom found near: 007E0000
Detected ffs/eeprom address is non-standard: 007E0000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 007E0000
detecting ffs/eeprom size...
ffs/eeprom size: 00020000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:007E0000-007FFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: C500MK_PCB01_GPRS_MT6223P_S00.SIMOCO_SM234_V1_00_02__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\C500MK_PCB01_GPRS_MT6223P_S00.SIMOCO_SM234_V1_00_02__fullflash_20091213-120034.B0M simoco sm324
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\C500MK_PCB01_GPRS_MT6223P_S00.SIMOCO_SM234_V1_00_02__system_log_9F8FAE10_04978024_20091213-120055.B0X.bin
Finished, time used: 284 sec
Remove/Install battery now !
HEARE IS PIN CONNECTION:-
searching adapter at COM6...
adapter found, version: 2000
pins: 12, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6223
result: Rx:1 Tx:7
time required: 3 sec
Trying to Power-On...
Power On !
saved: SIMOCO_SM234
HEARE IS UPLOADED LINK:-
The Following User Says Thank You to debmobile For This Useful Post:
Old 12-13-2009, 09:07   #2 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,414
its chinese mobile you have post in chinese miracle section !!
and please upload on Rapidshare.com
Thanks
Faisal_Computer
Old 12-13-2009, 10:36   #3 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
thanks for uploading of file
it will help so many members in future
Old 12-13-2009, 19:41   #4 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
THANKS BUT WH A SUPPORTER? CAN'T INCARRAGE & REPLY ,THANKS ALL.
Faisal_Computer DO U READ ERROR MSG? UPLOAD RAPID SHARE OR4SHARED
Old 12-14-2009, 06:53   #5 (permalink)
Member: 151871
hello,
supporters is busy to giving updates
no did not any error but if you upload in rapidshare it will easily to download
Faisal_Computer
Old 12-20-2009, 15:47   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
@mov009
Thank you, file downloaded.
We will check/prepare/upload it in support area ASAP.
Simoco sm-499 new firmware detected> debmobile Infinity-Box 2 02-19-2010 11:57
Simoco sm-999 new firmware detected> debmobile Infinity-Box 1 02-11-2010 20:37
<new model simoco sm-1200 new firmware detected> debmobile Infinity-Box 3 12-07-2009 08:02
Simoco sm-399 new firmware detected debmobile Infinity-Box 2 07-31-2009 17:20
Simoco Sm-498 New Firmware Detected. debmobile Infinity-Box 3 08-08-2008 10:49
Page generated in 0.35987 seconds with 8 queries
