10-17-2016, 11:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | Lyf ls-4006 frp lock remove Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000014CEF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following User Says Thank You to galaxycompue For This Useful Post: |
11-22-2016, 11:02 | #10 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Use latest CM2SPD software to remove frp, if any problem post here with logs. Br. Infinity Box Support Team. |
11-24-2016, 10:01 | #11 (permalink) |
Major Poster Join Date: Nov 2014 Location: Mangaldai
Member: 2294633 Status: Offline Thanks Meter: 15 | LYF LS-4006 FRP LOCK REMOVE with this tool tested from me 1. Mobile Go to fastboot mode 2. Connect mobile with pc 3. Press 9 & enter ok Android Fastboot Reset Tool V1.2 - Download - 4shared |
The Following 8 Users Say Thank You to saifulinbox For This Useful Post: |
11-30-2016, 12:06 | #12 (permalink) |
Freak Poster Join Date: May 2013 Location: India,Mysore
Member: 1930738 Status: Offline Sonork: 100.1638397 Thanks Meter: 80 | Lyf ls-4006 Put Nova Launcher And QuickShortcut Maker On ur SD Card First On Ur Phone ...Put ur phone Asking Google Account.. Then Hold @key Scroll than settings.... Then select Keypad Settings. ...and Select Typing settings..... Now Hold Down Back Key....Now U Got App Management... Select File Manager Open That .....install The Nova Launcher And Open it Then install QuickShortcut Maker...... Now open QuickShortcut Maker Select Google Account... Open That Click on Try Now u Login On Browser...... After Restart Ur Phone ......Set Ur Phone On Welcome....... That's It |
12-04-2016, 08:47 | #14 (permalink) |
No Life Poster Join Date: May 2012 Location: Sherghati (gaya) Bihar Age: 31
Member: 1761355 Status: Offline Sonork: 0818211 Thanks Meter: 105 | Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Huawei SPD FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 1.0 Product Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:14 [Module Ver. 3.3] Log Saved to Logs\161204_131200.log |
12-04-2016, 15:14 | #15 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Post in correct forum this is cm2 forum Sent from my S_plus using Tapatalk | |
