Old 10-01-2010, 17:25   #1 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
Need Help Pinfinder Not Detect Nokia Z200 and s1100 anycoll
I need Some Help With this Phone Pinfinder cant detect it, i use cable L12c But Failed to get pinout But Power on the Phone when Finish,any way to work This Phone..its the same connector for 2 phone.
http://img522.imageshack.us/img522/7...camerablue.jpg
Old 10-01-2010, 21:01   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
let start from beggining: are you sure that this is mt62xx MCU based phone?
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is mt62xx
Old 10-01-2010, 22:45   #3 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
Not Its No MT60xx Phone Dont Change the Language...What Can Do Now?
Old 10-03-2010, 11:00   #4 (permalink)
Member: 148515
hello!
in this case it is not supported by Chinese Miracle software.
you can disassemble your phone and check what MCU is inside.
this information will help you to find correct forum where to ask about it
Old 04-12-2011, 19:47   #5 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
hi
i have the same phone z200, nead to remove it's password, i found in its pcb some "U1TXD2 U1RXD2 UORXD UOTXD" pinouts but don't work. can't connect
does infinity support this phone ?
Old 04-13-2011, 07:18   #6 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
What cpu does the phone have?
If it is MT62xx then it's supported. You can check this by typing *#0044# and pressing green (send) button.
If it has SPD then currently not supported.
Wr.
Old 04-13-2011, 19:08   #7 (permalink)
Member: 148515
hello guys!
seems it is not MTK phone. check if you get response to any of these codes:
*#0044#, *#8375#, *#3646633#
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.15783 seconds with 9 queries
