Old 07-19-2007, 14:03   #1 (permalink)
david laborator's Avatar
Member: 228601
Thanks Meter: 56
hello infinity i need help
i have found a correct pinout for my chines miracle nokia n77 and i opened the support for download the files but i didnt see the files in support here my info
COM4 selected
Device: Autodetect
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Check space...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
memory structure: 2nd [enhanced] (or higher) generation
warning: make backup before any action !
warning: probably identification data damaged, power-on problem possible
error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.63F49E3F._BR26 _05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN_72A0E82E _.rpl
warning: unknown identification structure: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN_72A0 E82E
error: ASK file can't be created, user action required:
- find good working phone with the same firmware[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN]
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read Full Flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
identification detection finished
device-id: 63F49E3F
protocol version: 04
version sw1: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN
version sw2: BR26_35.11
ffs offset/size: 00E00000/00200000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
detecting structure pass 1...
detect standard location pass #1...
detect extended location pass #1...
detect standard offset pass #1...
detect standard data...
layout detection complete
eeprom element #1 detected ok
reading [eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN]]...
file saved: backup_eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN]_20070719-150724.B0E.bin
Check space Done
Manipulation...
detection procedure, wait...
detection procedure completed
Manipulation Done
Finalization...
Finalization Done
Write...
Write: eeprom
Write Done
Finished, time used: 486 sec
Remove/Install battery now !
and here is my flash buck up from my infinity
http://www.sendspace.com/file/l2h4lj
Old 07-27-2007, 02:55   #2 (permalink)
kramlester_14's Avatar
Member: 405608
Sonork: marklester
Thanks Meter: 47
hello gud morning mate!!!!i finally done with my n77 no network!!i reheat the helga of this phone and it already work!!!!!
Old 07-28-2007, 21:52   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
@david laborator
Could you, please, explain me more detailed what need to do with your phone and what is the problem ?
Old 08-30-2007, 11:10   #4 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 319
COM4 selected
Device: Autodetect
Action: unlock
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Check space...
device-id: 63F49E3F
eeprom chip: 00
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
Write: eeprom
Write Done
Hi,
Please can you help me pinout for n77, the link you provided is expired now
Old 02-01-2008, 10:26   #5 (permalink)
sonumobilewala's Avatar
Member: 296651
Sonork: 100.1581376
Thanks Meter: 386
hi infinity i need cect n77 pinout plz help me
Old 02-02-2008, 17:31   #6 (permalink)
Member: 130995
Dear Friend,
Currently many "Chinese" models with the same name but absolutely different hardware exist on market,
f.e. exist at least 20 phones with name "Chinese Nokia-N95"
but with different
bottom connectors and different pinouts, so we recommend you to include the next information in your question regarding pinout:
1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, you can find pinout by yourself more easy than before,
just check the next detailed description how to get pinout for your model:
1. use "Cable Selector": "Cable selector" at your service...
2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
3. if not helps, please read: http:///vbb/showpo...36&postcount=7
4. if not helps, please read: http:///vbb/showthread.php?t=433447
Old 02-05-2008, 18:15   #7 (permalink)
Member: 296651
Sonork: 100.1581376
Thanks Meter: 386
dear sir plz give me picture for cect n77 pinout
Old 02-05-2008, 18:29   #8 (permalink)
Member: 348451
Thanks Meter: 2
hey sonumobilewala what's your problem man
infinity support told that u need to find the pinout on your own so do it and stop complaining
Old 02-06-2008, 02:56   #9 (permalink)
Member: 148515
Thanks Meter: 16,145
hello!
i just not sure that mr. sonumobilewala saw my partner post.
because i dont see reason why he posted his question again ignoring text in Bold Yellow.
We cant spend time for helping people who dont even post a connector type!!!
we better will spend this time for updates
hello infinity team pls help FullFlashPak Infinity-Box 1 06-14-2009 19:28
hello infinity team plz help me ....... abid dar Infinity-Box 6 04-08-2009 10:19
Hello Infinity Team Plese Help How Can I Found 2cpu Pinout In Pinfinder? debmobile Infinity-Box 4 08-26-2008 07:11
HELLO infinity team need your help debmobile Infinity-Box 1 05-30-2008 17:11
hello infinity i need help david laborator Infinity-Box 1 09-12-2007 09:15
Page generated in 0.38437 seconds with 8 queries
