04-08-2009, 14:07 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: United Kingdom
Member: 621787 Status: Offline Thanks Meter: 142 | Hello Infinity Team help me plz.......... COM5 [VCP0] selected module v2.69 Device: Lobster-544 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8A01]... CPU: MT6219 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .............................................. detect device identification#1 finished identification#1 protocol ver: 01 ver. sw 1: MP500_UK_PCB01_GPRS_MT6219_EV.MP500_W05_20_MP_V53. BIN ver. sw 2: MP500.W05.20.MP.V53, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data ... ................ lock area found Patch required data Done Special operation ... Special operation Done Write ... flash: B0001D00000000:B0001D00000000 flash: B0001D00000000:B0001D00000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 59 sec Remove/Install battery now ! ok infinity team |
04-09-2009, 11:15 | #3 (permalink) |
Member: 621787 Status: Offline Thanks Meter: 142 | i try all methot butt same error i when i enter the np code second setp master code when i enter the master code so (wrong master code ) show..........so what i do tell me infinity team.. |
04-09-2009, 13:02 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to make unlock with "smart fast" method ? If problem still exist read full flash from phone and send it to [email protected] |
04-09-2009, 13:29 | #6 (permalink) |
Member: 621787 Status: Offline Thanks Meter: 142 | infinity team when i enter NP code so ok butt second setp it sp code its so long so u tell me who i enter it in set.... NP code: 03405684/30046548 locked to: 234-30 SP code: 0000000000003344/0000000000003344 CP code: FFFFFFFFFFFF0000/FFFFFFFFFFFF0000 IMSI code: 4040104768060000/0404017486600000 Phone code: 0000000000000000 Finished, time used: 20 sec Remove/Install battery now ! |
04-09-2009, 18:18 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to read codes again with this new software: http://www.infinity-box.com/download...dule_v2.70.rar Waiting for your results ! |
04-10-2009, 15:02 | #8 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | Quote:
brother try to format ffs and then unlock..................... best up lock ............all the best ........... | |
04-10-2009, 16:49 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I think that with latest MModule everything should be Ok. Let's wait results from thread starter. |
04-11-2009, 12:01 | #10 (permalink) |
Member: 621787 Status: Offline Thanks Meter: 142 | A lots of a thanks infinfity team................ I have been unlock Lobster 544 with latest version. Show here ................. SET NO 1.............. COM5 [VCP0] selected module v2.70 Action: read codes unlock method: read codes Model: Lobster-544 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8A01]... CPU: MT6219 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219,E01 Date: 2004.06.18 Version: 1.2.1.4 Version: MP500.W05.20.MP.V53 Version: VerH/W:0.1 65 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 69 byte(s) read Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: On Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 89829610/98286901 locked to: 234-30 NP of SP: 234-30 SP code: 94506405/49054650 Phone code: 0000 Finished, time used: 19 sec Remove/Install battery now ! SET NO 2.............. COM5 [VCP0] selected module v2.70 Action: read codes unlock method: read codes Model: Lobster-544 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8A01]... CPU: MT6219 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219,E01 Date: 2004.06.18 Version: 1.2.1.4 Version: MP500.W05.20.MP.V53 Version: VerH/W:0.1 65 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 69 byte(s) read Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: On Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 89829610/98286901 locked to: 234-30 NP of SP: 234-30 SP code: 94506405/49054650 Phone code: 0000 Finished, time used: 17 sec Remove/Install battery now ! very very thanks full 2 you........ |
The Following User Says Thank You to abid dar For This Useful Post: |
hello furiuos team help me plz | naveedbutt | FuriousGold | 6 | 04-10-2010 09:50 |
Pzl plz plz infinity team help me....... | abid dar | Infinity-Box | 1 | 05-06-2009 19:43 |
plz infinity team help me | robin25 | Infinity-Box | 1 | 08-26-2008 14:43 |
plz infinity team help me in dide n99i 2 serial after flash fone | KhOliO | Infinity-Box | 4 | 07-08-2008 00:03 |
plz infinity team help me in dide n99i 2 serial after flash fone | KhOliO | Infinity-Box | 2 | 07-06-2008 20:40 |
