10-18-2016, 23:52 | #1 (permalink) | |||
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Hello Infinity Team Here Are Some Issue N Suggestion For CM2 Kindly Fix/Add Hello Team I Am Using CM2 From Long Time N Satisfied Too But I Found Few Issue Which Need To Fix So I Am Posting Here So You Can Check N Fix N Make Tool More Better ....I Also Having Some Suggestion For Your Tool Hope It Also Implemented As Well.... So Lets Start With "Rockchip" Module I Am Having 1 Tab Which Came On 4 Variant Wid Diff. OS N Touch But Processor Is Same.... I Found Tool Having Issue Wid Read Flash File On OS 4.1 & 4.2.... Os With 4.4 & 4.4.2 Read Well N Also Write Without Issue.... Logs Here Read Info Quote:
Screenshot Half Readed File Link https://forum.gsmhosting.com/vbb/****************************/?1b7emfhsikadgag Now SPD I Found Some SPD 6531 Read Password Fail On Infinity As Well As Other Tool....With Infinity Show No Code Set...With Other Tool Show Wrong Password... Quote:
Readed File Dump https://forum.gsmhosting.com/vbb/****************************/?i1cfl123306w2wd Also Kindly Revised Flashing For SPD Android When Write System Hangs Alot N Sometimes Fail Again N Again.... RDA Module Also Having Issue When Flash Handset It Fail In Middle Of Action While Factory Tool Done It....Sorry For This Report Log Not Available As I Found This Few Moths Back N Also Report But Not Fix Even After New Ver. Launch Issue Wid Mostly Intex N Spice Brands Kindly Check N Fix It .... After Few Handset I Kill I Stop Using RDA Module N Use Factory Tools Now For Operations. Old Thread http://forum.gsmhosting.com/vbb/f296...found-1993223/ Lastly About MTK MTK Working Good ...But I AM Having Few Advises For MTK Kindly Add Specific/Desire Area Flash Option Like User Data Recovery Add Support Area Button So We Can Directly Access Support Without Installing Shell... Or Make Support Shell Inbuilt In Software. Add NVram Check Option To Check For Crash/Formated NV Area. Add IMEI Auto checksum Last Digit Will Appear So We Can Check Type No. Ok Or We Make Mistake Somewhere. Add Latest Dongle Manager On Infinity Directory With Setup Installer I Saw Many People Asking For Dongle Manager Link Or Use Old Dongle Manager Or If Possible Add Support Expire Date Show On Cm2. Make 1 Option For Test Storage Before Flash/Erase Chip....I Saw This In Old Ver Not Check Wid New Now When U Flash With Tick Erase Before Flash Option N If Storage Emmc Damage With Erase Chip Then Stop & Handset Becomes Dead (Which Was In Logo Before) Mostly Give BROM ERROR : S_DL_PMT_ERR_NO_SPACE Something Like This.... Add Option To Select Com Port So We Can Use Infinity Box Or Other Box As Pinfinder By Selecting Their Com. Hope Team Take This In Positive Way N Use All Above For Fix Issue ....Waiting For Positive Reply From Team Above Files Are Protected With Pass I Give To Team Via PM Thanks Br. Hi-Tech Care | |||
The Following User Says Thank You to hitech care For This Useful Post: |
10-19-2016, 00:18 | #2 (permalink) | |||
Member: 1834832 Status: Offline Thanks Meter: 1,450 | 1 More Issue With SPD Module... I Read 1 Handset Firmware With CPU 9830 But After Convert It To .Pac All File Details Change To 77XX I Think Will Be Better If Save With Same Processor To Identify CPU Or To Do Any Operation... Here Are Logs.... Read Factory Firmware Quote:
Convert SPD Infinity File To Factory File Quote:
I Am Having 1 MTK Phone Dump Too Which Gives Error While Read Factory File Or Read Pattern Lock But Full Dump Read Success If U Really Interested To Check Tell Me I Will Upload Full Dump. Br. Hi-Tech Care | |||
10-19-2016, 00:59 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. About identify - will revise that moment. Rename to SC7731 happen due there is no compilation info found about CPU. Will make by other way or some combined method. Rest will be checked as well. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
