10-21-2007, 14:53 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Paris Age: 47
Member: 113924 Status: Offline Thanks Meter: 29 | Lg KG290 unlock error COM5 [VCP128] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 357456012620xxx file saved: backup_eeprom_357456012620xxx_LG KG290_20071021-154441.B1E.bin .............. Check flash Done Check space... current eeprom imei: 357456012620xxx .................................................. .............. finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done error: wrong answer[C1] Finished, time used: 38 sec Remove/Install battery now ! |
10-21-2007, 15:19 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | pls, try to repeat unlock process. if it will be problems pls send backup eeprom file and operation.log file to [email protected] |
10-21-2007, 19:31 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | try to use "unlock method: enhanced" if no luck: http:///vbb/showpo...19&postcount=2 |
LG - KG290 flashing error | Dilip_Nath | Infinity-Box | 33 | 03-11-2011 18:57 |
LG KG290 Flashing Error | ARS.Rehman | Infinity-Box | 9 | 04-08-2009 13:34 |
what cable for lg kg290 unlock? | JOHN2003. | HWK | 3 | 06-04-2008 08:54 |
LG KG290 unlocked in infinity-box using standard method | amps_jas | Infinity-Box | 1 | 01-08-2008 13:56 |
Lg Kg290 Unlock Ok | PARMATMA | Multi-box LITE | 0 | 10-31-2007 07:52 |
