Old 02-28-2008, 07:34   #1 (permalink)
.::PATEL TELECOM::.'s Avatar
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
hello sir tecno st600 pinout need
Hello sir i have tecno st600 it has restart and i want its pinout and hot solved this restart problem
Old 02-28-2008, 07:48   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
How to get new model supported
Question: I have new phone model and I want to see this model supported by Infinity-Box. What to do ?
Answer:
1. open phone, find CPU chip and Flash chip
2. send e-mail to [email protected] with the next info:
2.1. CPU chip name
2.2. Flash chip name
2.3. phone bottom connector type (photo, if available)
2.4. Gnd, Charge, +Battery pins location on phone connector
2.5. full text from phone back label (label under battery)
2.6. phone photo (or link to phone photo)
2.7. is it sp-locked or simfree phone
2.8. is it exist original data/com/usb cable in phone package
2.9. is it exist CD with original drivers in phone package
2.10. estimated phone price
2.11. any additional information
We will check your information and will tell you is it possible to make support for this model or not.
Old 02-28-2008, 08:39   #3 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
Respected sir it is suported by you i see in infinity sell this model "TECNO st600" i want its pinout
Originally Posted by InfinitySupport View Post
Hello,
Answer:
2.1. CPU chip name
Old 02-28-2008, 09:26   #4 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
@.::PATEL TELECOM::.
can you share here which connector in your phone;
ps: check X:\Program Files\InfinityBox\pinout
there are 3 different pinout for tecno phones
br
Old 02-28-2008, 16:53   #5 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
sir i uplode its photos
sir i send some picture of tecno st600
Old 02-28-2008, 16:59   #6 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
here is socket print
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
plese give me its pinout
Thanking you
prakash
File Type: txt tecno st600.txt (91 Bytes, 12 views)
Old 02-28-2008, 20:36   #7 (permalink)
Member: 130995
keyboard top
1.........18
9: Tx
10: Rx
18: Gnd
Old 02-29-2008, 06:52   #8 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
sir this errr is coming. HOW repair this phon it is restsrt where i find eprom
COM5 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: repair security area
Boot...
error: boot initialization step-2 failed: A0
error: boot initialization step-3 failed: A0
19200
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 8 sec
Remove/Install battery now !
Old 02-29-2008, 10:03   #9 (permalink)
Member: 130995
You must use other pinout, it's a pinout problem, not a phone eeprom problem !
Old 02-29-2008, 10:42   #10 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
keyboard top
1.........18
9: Tx
10: Rx
18: Gnd
i tried both of side but same problem
so sir what i do for this problem
Old 02-29-2008, 11:39   #11 (permalink)
Member: 130995
Hello,
Here is an instruction:
There are different "Chinese" phones with the same name but absolutely different hardware exist on market.
Exmple: exist at least 20 "Chinese" phones with name "Nokia-N95" but all models has difference in hardware,
different bottom connectors, different pinouts and and has different firmware, so it's impossible to
give any advice about phone pinout only by phone name.
So we recommend you to include the next information in your request regarding pinout:
1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, you can find pinout by yourself more easy than before,
just check the next detailed description how to get pinout for your model:
1. use "Cable Selector": "Cable selector" at your service...
2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
3. if not helps, please read: http:///vbb/showpo...36&postcount=7
4. if not helps, please read: http:///vbb/showthread.php?t=433447
Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en
tecno t780 pinouts needed pleaseeeeeeeeeeeeeeee GOODNESS Chinese Models & Cloned Phones 2 08-14-2010 15:09
Tecno S598 rx/tx pinout needed Unicom Infinity-Box 2 01-18-2010 10:07
Hello sir need Sales Activation license kushol Sales Activation Requests 0 03-10-2009 15:21
tecno ST600 plus alimuamin Infinity-Box 0 05-24-2008 08:07
Need Tecno T800 Pinout DYNET Infinity-Box 1 09-17-2007 20:44
Page generated in 0.42741 seconds with 9 queries
