01-04-2017, 06:20 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1145188 Status: Offline Thanks Meter: 5 | CM2QLM clearzuk z2 password ok Operation : Reset UserLocks [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 801 [MSM8974] ID_BLOCK_S : 11A17C15 ID_BLOCK_I : 007B40E1 ID_BLOCK_L : 94D37E0CBF769C0CAA92DA971CE61CF5 ID_BLOCK_L : 53E54CF67E49347C22B2032A22304329 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/00020000/00001000/00001000 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Processing step #4 Processing step #5 Processing step #6 Processing step #7 UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
The Following User Says Thank You to mobiletan For This Useful Post: |
