08-07-2016, 19:32 | #1 (permalink) |
Insane Poster Join Date: Jun 2016 Location: My Computer
Member: 2582286 Status: Offline Thanks Meter: 14 | Hello Team Any Solution For This... Code: Operation : Flash Erase [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010051375853414201296FD0B21285 Initialize Memory ... DRAM already initialized by Preloader [DA_ERROR] : DA Load failed! ErroCode : 0x2008 DA_LOAD_FAILED Boot Error! Operation Failed Elapsed: 00:01:00 Reconnect Power/Cable! |
08-08-2016, 02:27 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Check and charge battery, use original short USB cable. Use latest CM2MTK module. |
