07-07-2016, 18:36 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Lagos Nigeria
Member: 1840260 Status: Offline Thanks Meter: 166 | hello team huawei y336 need help Today i got a huawei y336-u02 i tried to flashing using sd card update but i cant because i get phone has been rooted error i later download the pac file from cm2 support and cant flash with cm2 spd i choose the y332 sldr from models folder still cant read info. or flash ======= Flash Files set for flashing : [ MCU ] : Y336-U02V100R001C567B108.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A_INFINITY PacVersion : Y336-U02V100R001C567B108-INFINITY File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo_1.bmp File : sysinfo.img File : customspc.img File : prodnv.img File : cache.img File : u-boot.bin File : dlstat.bin File : globalinfo.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [7/7/2016 / 10:21:39 AM] SLDR Load Ok BB CPU : SC7731 Huawei Y336-U02 (Y3C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [7/7/2016 / 10:22:28 AM] Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [7/7/2016 / 10:22:55 AM] SLDR Load Ok BB CPU : SC7731 Huawei Y336-U02 (Y3C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [7/7/2016 / 10:24:22 AM] Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [7/7/2016 / 10:24:50 AM] Start at : [7/7/2016 / 10:24:59 AM] Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 44 ] Open Port Failed! Reconnect Power/Cable! Finish at : [7/7/2016 / 10:25:00 AM] Start at : [7/7/2016 / 10:25:03 AM] Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 43 ] Open Port Failed! Reconnect Power/Cable! |
07-07-2016, 18:40 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Seems as phone have another HW version. Way is only checking over net another HW versions. Also try boot it as Y5. |
