Old 05-15-2011, 14:04   #1 (permalink)
Member: 681346
Thanks Meter: 14
Question hellp me vadafon 345
module v3.75
Device: Vodafone-345
Checking data, wait...
Action: read ffs/eeprom
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
chip: 0011:4C42:A00C
status: 01
warning: unknown or damaged hardware
boot packet size: 0400
error: bootcode load error: A0
Release Power button now !
Boot Done
====> Initialize ...
error: no any expected answer : wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
flash chip is unknown or damaged.
Fault reasons:
1. flash chip is damaged: replace or resolder/reball flash chip
2. hardware is damaged: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 23 sec
Remove/Install battery now !
Old 05-15-2011, 14:44   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,027
Try with latest MModule v3.89
BTW your log shows damage hardware, what was problem with the phone?
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 05-15-2011, 14:55   #3 (permalink)
Member: 681346
Thanks Meter: 14
Smile thanks
COM20 [VCP5] selected
module v3.89
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
flash: 2088BAFFFFFFFF:2088BA00000000
flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
error: unexpected data: 15000000C7
warning: wrong data size at 0x0001F140, retry...
read error recovered
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
version: 869
provider: V345X-2AVDLK1
customization: CM86KS50
customization: XM86KS50
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 0000B280344552
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20110515-182424.B0X.bin
Finished, time used: 2 min 15 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 05-16-2011, 01:46   #4 (permalink)
Member: 1043909
Thanks Meter: 52,180
It's always good idea to use latest software updates from Infinity-Box support area.
We add support for new software/hardware types at regular base.
Can anybody help me with solution to change 51/61/3210 IMEI? soff Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-08-2011 15:28
REWARD-Please can somebody help me unblock a orange nokia phone and unlock 6150 andrew bennett Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-07-1999 18:25
Sp unlocking sim - if you can get or sell please let me know andrew bennett Wanted Products 1 09-24-1999 09:43
Page generated in 0.27113 seconds with 8 queries
