07-14-2008, 16:35 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Egypt - Elmahalla Elkobra Age: 41
Member: 30073 Status: Offline Thanks Meter: 18 | help with 2 sets i have Cect T888 & CNokia N972 the two sets with hang problem.... the two sets with CPU :- MT6226 i tried many times but i can't detecting pins by using pinfinder software version: 1.11 cable type: 1x12 (L12C) platform: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 65 sec Power Off ! what is the problem here |
07-14-2008, 17:04 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | FOR BATTER RESULT PINFINDER PUT THIS CAPA 470mf/10v and your problem is connector,cline connector, or chang,if no result rehit cpu. |
07-14-2008, 22:10 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, if you have problems with powering phone from pinfinder power- you must remove diode and set capacitor. procedure is described in user manual. only when phone can be powered On from pinfinder power- pinout can be found |
08-06-2008, 11:25 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! for increasing box output voltage- you must desolder diode fronm infinity box. to solve not_powering_on problem- you must add capacitor to pinfinder box please check latest pinfinder user manual |
NOOB needs help with wap settings for w810i on roger netowrk | lankan_soldier | Sony Ericsson | 0 | 08-10-2006 00:10 |
Please,i need some help with network settings!! | MYSELF28 | Sony Ericsson | 1 | 06-21-2006 15:30 |
Nokia 6170 help with gprs settings | suzywoo | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-30-2005 19:00 |
