08-24-2008, 18:57 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 742181 Status: Offline Sonork: correction to an action Thanks Meter: 2 | help ==== log opened: [8/20/2008 11:51:10 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.45 S/N: 48E1:010F Wait... Device: Autodetect 6205-6227 NOR Done COM26 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E603:000F boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: 6302_W180_ML_V04.6302_W180_ML_V04.BIN ver. sw2: 6302_W180_ML_v04, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[6302_W180_ML_V04.6302_W180_ML_V04.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[6302_W180_ML_V04.6302_W180_ML_V04.BIN]_20080820-120903.B0M.bin Finished, time used: 1110 sec Remove/Install battery now ! COM26 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E603:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: 6302_W180_ML_v04 Version: 6225_GEMINI_HW detecting structure #2... 5 11 18 24error: detection failed (4 tries), read flash and send to support connection Ok detecting structure #1... 1 5 7 8 9 10 12 13 15 19 21 22 23 24 26 27error: detection failed (16 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! COM26 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E603:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: 6302_W180_ML_v04 Version: 6225_GEMINI_HW detecting structure #2... 5 11 18 24error: detection failed (4 tries), read flash and send to support connection Ok detecting structure #1... 1 5 7 8 9 10 12 13 15 19 21 22 23 24 26 27error: detection failed (16 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! now ! Wait... Device: Autodetect 6205-6227 NOR Done COM26 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E603:000F boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: 6302_W180_ML_V04.6302_W180_ML_V04.BIN ver. sw2: 6302_W180_ML_v04, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[6302_W180_ML_V04.6302_W180_ML_V04.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[6302_W180_ML_V04.6302_W180_ML_V04.BIN]_20080820-120903.B0M.bin Finished, time used: 1110 sec Remove/Install battery now ! COM26 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E603:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: 6302_W180_ML_v04 Version: 6225_GEMINI_HW detecting structure #2... 5 11 18 24error: detection failed (4 tries), read flash and send to support connection Ok detecting structure #1... 1 5 7 8 9 10 12 13 15 19 21 22 23 24 26 27error: detection failed (16 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 9 sec COM26 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E603:000F boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: 6302_W180_ML_V04.6302_W180_ML_V04.BIN ver. sw2: 6302_W180_ML_v04, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[6302_W180_ML_V04.6302_W180_ML_V04.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[6302_W180_ML_V04.6302_W180_ML_V04.BIN]_20080820-120903.B0M.bin Finished, time used: 1110 sec Remove/Install battery now |
08-24-2008, 20:11 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Code: detecting structure #2... 5 11 18 24error: detection failed (4 tries), read flash and send to support connection Ok detecting structure #1... 1 5 7 8 9 10 12 13 15 19 21 22 23 24 26 27error: detection failed (16 tries), read flash and send to support |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
help [ANSWERED] | mariusgsm76 | Nano-Box | 2 | 04-01-2010 11:33 |
HELP how to unlock iphone 3.1 | laksh007 | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 03-31-2010 03:22 |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
