02-21-2011, 13:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | need to improve operations on 6253 Device: Autodetect 6253 NOR WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [2/21/2011 3:48:50 PM] ==== COM50 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 19 sec Remove/Install battery now ! |
02-21-2011, 13:10 | #2 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | Loading data, wait... [Infinity Box] Chinese Miracle v3.25 smart-card: connected S/N: Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [2/18/2011 4:36:27 PM] ==== COM50 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 30 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [2/18/2011 4:37:15 PM] ==== COM50 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 57 sec Remove/Install battery now ! ==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [2/18/2011 4:38:45 PM] ==== web site: Infinity-Box - About Loading data, wait... [Infinity Box] Chinese Miracle v3.26 smart-card: connected S/N: 66F0:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6228-6253 NAND WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [2/18/2011 4:39:00 PM] ==== COM50 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6228-6253 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 29 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [2/18/2011 4:39:49 PM] ==== COM50 selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6228-6253 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 26 sec Remove/Install battery now ! Last edited by InfinityHelp; 06-27-2020 at 10:17. Reason: legacy links removed |
02-21-2011, 13:14 | #3 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | ==== [2/1/2011 4:41:30 PM] ==== COM39 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 ==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [2/1/2011 4:42:13 PM] ==== web site: Infinity-Box - About Loading data, wait... [Infinity Box] Chinese Miracle v3.26 smart-card: connected S/N: Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [2/1/2011 4:42:26 PM] ==== COM39 [VCP1] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35error: detection failed (36 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 1 min 23 sec Remove/Install battery now ! In most cases you can read "firmware" instead of "full flash", it may helps to save a lot of time with the same functionality. Suggestion: read "firmware" now Do you want to read "firmware" instead of "full flash" ? ==== [2/1/2011 4:44:04 PM] ==== COM39 [VCP1] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 07E9:S_BROM_LOCK_POWERKEY_FAIL error: last error: 07E9:S_BROM_LOCK_POWERKEY_FAIL Disconnect... done Finished, time used: 8 sec Remove/Install battery now ! In most cases you can read "firmware" instead of "full flash", it may helps to save a lot of time with the same functionality. Suggestion: read "firmware" now Do you want to read "firmware" instead of "full flash" ? ==== [2/1/2011 4:44:15 PM] ==== COM39 [VCP1] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: C100.XT.NASAKI01.100926.02 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: TELSDA53_SLIM_09A_PCB01_GPRS_MT6253_S00.C100_XT_NA SAKI01_100926_02.BIN project-id: C100.XT.NASAKI01.100926.02, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.26, database date: 19.01.2011): TELSDA53_SLIM_09A_PCB01_GPRS_MT6253_S00.C100_XT_NA SAKI01_100926_02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 14Mb number of areas/bytes to read: 1:00E00000 reading (HW_STORAGE_NOR)... file saved: C:\Documents and Settings\Administrator\Desktop\TELSDA53_SLIM_09A_P CB01_GPRS_MT6253_S00.C100_XT_NASAKI01_100926_02__f irmware_20110201-165205.B0M.bin Disconnect... done Finished, time used: 8 min 0 sec Remove/Install battery now ! Last edited by InfinityHelp; 06-27-2020 at 10:17. Reason: legacy links removed |
02-27-2011, 06:08 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, try to use this new software: http://www.infinity-box.com/download...dule_v3.77.rar 1. select model Huawei-G6620 2. make full flash backup for emergency case ! 3. try to repair imei (DO NOT try to make other operations, this software for imei only) Please, post here operation log. Waiting for your results. |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
