02-11-2006, 17:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: gsm market Age: 35
Member: 222481 Status: Offline Thanks Meter: 30 | HELP a100 no network after flash please help me infinity team |
02-11-2006, 17:32 | #2 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | check this procedure HOW TO repair "No network" and "Bad Imei" for A100/A101/A102 after bad unlock/flashing. 1. Make sure you have checked "Backup" options in "Settings" page. 2. Flash phone with latest firmware 027 (all parts: MAIN+MAP+LP) 3. Go to "Flash" page and select area "EEPROM". 4. Select first "A100_Repair_EEP" file from "EEPROM_REPAIR" folder. 5. Flash it into phone 6. If phone become locked after flashing, use ordinary "Unlock" procedure to rebuild security area. 7. Test phone (Network, Imei, charging). 8. If phone works not good, then repeat from step 4 with other "A100_Repair_EEP" file. regards |
02-11-2006, 19:16 | #7 (permalink) | |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
after that flash it with eeprom | |
04-28-2006, 18:55 | #8 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Delhi
Member: 138575 Status: Offline Thanks Meter: 58 | Followed all above procedure, with mentioned flash file also. But the phone dosent show any network/900 r 1800. IMEI is perfectly alright. Repair eeprom also done. NO sign of any network. Please help INFINITY TEAM. |
04-28-2006, 20:00 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hi, Check what is current phone firmware: *#369#* Make backup ("read flash") for emergency case. Try to flash different flash files set (main+lp+ffs). How to select flash files set: look in support area in "FlashFileDescription" document. I am not sure that this helps 100% but if it will be no network after this operation and all flash files - i think it's hardware problem (even if no any visible defects on PCB). |
help ku990 no network after flash | raoul plus | LG | 13 | 12-15-2010 23:08 |
please help . KU990i no network after flash | samirtelecom | FuriousGold | 21 | 04-03-2010 14:46 |
Help NgageQD no network after flash | visionmaster20 | WD2 & APE (Symbian Phones) | 5 | 12-26-2007 10:55 |
need help kg225 no network after flash | hanen | HWK | 1 | 10-14-2007 22:17 |
Help .. C353 No network after flash | CellM@n | Motorola P2k | 3 | 03-29-2005 07:18 |
