12-10-2016, 15:29 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Infinity Team Help Me Please.. i hop Team and My friends Understand My Question. Thanks in advance Regards .::Mustafa::. |
12-10-2016, 16:05 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Infinity-Box CM/CM2 already supports .bin file format, so there shouldn't be any problem in using it. About conversion it's not possible for now. Br. Infinity Box Support Team. |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
12-11-2016, 07:59 | #3 (permalink) |
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | sir thanks to reply but i face problem in bin file i read bin file with other box just like Miracle box and Volcano box when i load the bin file with cm2 show u load the bad or unsupported file But other box Flash done with same file .In That resin i convert bin file to Scatter file .I can not Flash the phone with Bin file with Cm2 Dongle. |
12-11-2016, 11:02 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Br. Infinity Box Support Team. | |
12-11-2016, 14:03 | #8 (permalink) | |
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Quote:
1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xC3555188BF151143E96970694DE6461C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Please add bin to file converter in Great Tool CM2 Regards .::Mustafa::. | |
12-11-2016, 14:44 | #9 (permalink) | |
Freak Poster Join Date: Feb 2013 Location: algeria
Member: 1882912 Status: Offline Sonork: 100.1677703 Thanks Meter: 263 | Quote:
it's Nand chip NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xC3555188BF151143E96970694DE6461C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! | |
