02-05-2009, 17:22 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 519797 Status: Offline Thanks Meter: 6 | "JAZZ"Mobile T161L unlock Done All Sim Work 1000000% COM5 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090205-203903.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090205-203905.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090205-203911.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090205-203930.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! thanks infinity team |
The Following User Says Thank You to Mjabbar For This Useful Post: |
02-05-2009, 18:13 | #2 (permalink) |
Freak Poster Join Date: Mar 2006 Location: 03218554185 Age: 43
Member: 243881 Status: Offline Thanks Meter: 68 | bro i need pinout "JAZZ"Mobile T161L |
02-05-2009, 18:22 | #4 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
02-06-2009, 21:03 | #6 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Quote:
The Following User Says Thank You to khadim100 For This Useful Post: |
Huawei-T161L UNLOCK DONE WITH LG-KG195 CABLE. | sajidashraf | Infinity-Box | 5 | 06-24-2010 06:50 |
Huawei-T161L unlock done with infinity | imran_hasham007 | Infinity-Box | 2 | 05-05-2009 17:36 |
huawei t161l unlock done | nadim electro | Infinity-Box | 1 | 03-03-2009 17:04 |
zong t161L unlock done | gsm-world | Infinity-Box | 1 | 01-29-2009 10:09 |
huawei t161l unlock done | nadim electro | Infinity-Box | 2 | 01-28-2009 13:50 |
