05-02-2011, 14:51 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Help: Alcatel 565 dead after unlock!!! COM5 [VCP0] selected module v3.80 Device: Alcatel-565X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:889E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.630E5653 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN_91149072].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 630E5653 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN project-id: MAUI.08A.W08.36.SP1.V40.F4, 72901491 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: E36 provider: 565X-2ARGRO1 customization: CPE3CC2C customization: XPE3CC2C TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XPE3CC2C customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35355004143097 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-565X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V40_F4__system_log_630E5653_91149072_20110 502-165037.B0X.bin Finished, time used: 4 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-02-2011, 19:09 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,948 | For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock: 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" |
05-02-2011, 21:16 | #3 (permalink) | |
Member: 148032 Status: Offline Thanks Meter: 415 | Quote:
I have managet to repair phone after "Repair security area" option but after unlock again, phone died again...lucky It can be repaired easly now... How to unlock this phone (I have allready tryed flashing with other firmware from support) ???????????/ COM5 [VCP0] selected module v3.80 Device: Alcatel-565X Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:889E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.630E5653 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN_91149072].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 630E5653 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN project-id: MAUI.08A.W08.36.SP1.V40.F4, 72901491 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: E36 provider: 565X-2ARGRO1 customization: CPE3CC2C customization: XPE3CC2C TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CPE3CC2C customization name adjusted customization: CPE3CC2C customization name adjusted customization detected: CPE3CC2C customization: CPE3CC2C flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35355004143097 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-565X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V40_F4__system_log_630E5653_91149072_20110 502-230831.B0X.bin Finished, time used: 3 min 3 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
06-20-2011, 09:03 | #5 (permalink) |
Insane Poster Join Date: Sep 2003 Location: ROMANIA Age: 45
Member: 39420 Status: Offline Thanks Meter: 2 | Alcatel OT-565 Dead I have the same problem here ! After unlock with infinity the phone was dead. When i push power the "Alcatel" logo start and after 10 sec phone power OFF ! Any solution Infinity TEAM ?? Thx ! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
