09-25-2008, 05:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: HYDERABAD
Member: 126000 Status: Offline Sonork: 100.1593044 Thanks Meter: 111 | nec com n880 need flash file Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:878B:A904 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.1B56A783.[SMEEL26_06B_PCB01_GPRS_MT6226_S01.M618_3_70_XXXX0V 0SA75VX_0512.BIN_90F2E6EB].rpl ==================== New firmware detected: SMEEL26_06B_PCB01_GPRS_MT6226_S01.M618_3_70_XXXX0V 0SA75VX_0512.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 1B56A783 identification#1 protocol ver: 04 ver. sw1: SMEEL26_06B_PCB01_GPRS_MT6226_S01.M618_3_70_XXXX0V 0SA75VX_0512.BIN ver. sw2: M618_3.70_XXXX0V0SA75VX_0512, 14190D6F ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... .................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_1B56A783_SMEEL26_06B_PCB01_GPRS_MT6226_S 01.M618_3_70_XXXX0V0SA75VX_0512.BIN_90F2E6EB_20080 924-221301.B0X.bin Finished, time used: 229 sec Remove/Install battery now ! |
The Following User Says Thank You to BHARGAV For This Useful Post: |
09-25-2008, 18:18 | #2 (permalink) |
Member: 126000 Status: Offline Sonork: 100.1593044 Thanks Meter: 111 | need flash files COM11 [VCP3] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:07E5:C21B high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:0E0E0400000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:0E0E0400000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 total flash region size: 02000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.18BAA1DB.[SZMI26_05C_PCB01_GPRS_MT6226_S01.S660_X6201A_SET_S P254J_V3_1.BIN_117F71B8].rpl ==================== New firmware detected: SZMI26_05C_PCB01_GPRS_MT6226_S01.S660_X6201A_SET_S P254J_V3_1.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 18BAA1DB identification#1 protocol ver: 04 ver. sw1: SZMI26_05C_PCB01_GPRS_MT6226_S01.S660_X6201A_SET_S P254J_V3_1.BIN ver. sw2: S660_X6201A_SET_SP254J_V3.1, 478E80EE ffs offset/size: 01E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 2 chip(s)... standard eeprom/ffs offset detected: 01E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... flash: 01227E22202200:0E0E0400000000 checking area[01000000]: 00000000-00FFFFFF... eeprom/ffs found near: 01E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 01 eeprom/ffs area: 01000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[SZMI26_05C_PCB01_GPRS_MT6226_S01.S660_X6201A_SET_S P254J_V3_1.BIN]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\flash[SZMI26_05C_PCB01_GPRS_MT6226_S01.S660_X6201A_SET_S P254J_V3_1.BIN]_20080925-212937.B0M.bin file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_18BAA1DB_SZMI26_05C_PCB01_GPRS_MT6226_S0 1.S660_X6201A_SET_SP254J_V3_1.BIN_117F71B8_2008092 5-212959.B0X.bin Finished, time used: 3565 sec Remove/Install battery now ! |
need nec com n880 2sim flash file | Reza.Ahmadi | SpiderMan | 4 | 04-09-2009 00:22 |
NEC com N880 | omguruom | SpiderMan | 0 | 01-07-2009 12:41 |
nec com n880 Need file flash orginal cpu 6226 | mehrdad20072 | SpiderMan | 1 | 07-31-2008 07:58 |
nec com n880 Need file flash cpu 6230 | mehrdad20072 | SpiderMan | 1 | 07-30-2008 07:29 |
Flashing Nec e616V failed! Need Flash file | dreamlearn | NEC | 0 | 06-11-2006 19:06 |
