11-08-2009, 17:39 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: never land
Member: 253726 Status: Offline Sonork: 100 1605478 Thanks Meter: 21 | help,can't boot mode any phone with pinfinder |
11-08-2009, 21:48 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! before searching pinout you must do 3 easy steps: 1. Make sure that this is mt62xx MCU based phone. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx. Now activate Silent mode in phone by pressing and holding "#". 2. Count number of pins in system connector. After this is done- pick correspondent cable. For example if you counted 2x6 pins- it is in total 12 so no point to put L14D cable instead of correct one, L12B. 3. Select cable type, connect power crocodiles in the place of battery. push "Power On!" in software. Now phone is powered with pinfinder power. Try to switch it On. This is main rule for success pinout search. (Phone must turn ON) if it does not turn On- no point to search for pinouts. you will not find it. Start from modifying your main infinity box to deliver more power to pinfinder. There is one diode which must be removed and shortcutted. Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done. after you get phone powered- you are ready to find phone pinout. press and Hold phone power button and start search. |
11-13-2009, 07:46 | #4 (permalink) | |
Member: 253726 Status: Offline Sonork: 100 1605478 Thanks Meter: 21 | still same problem with old model pinfinder Quote:
11-17-2009, 16:24 | #6 (permalink) |
Member: 253726 Status: Offline Sonork: 100 1605478 Thanks Meter: 21 | i have a pinfinder provided(new model) working 100%, but my pinfinder (old model) working in laptop only without charger.when connect laptop charger pinfinder can't connect any phone .maybe i can fix this problem sendme instructions please |
11-17-2009, 22:09 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Quote:
sorry, no idea. probably some power settings in your Laptop. | |
Can't flash any phones with usb | amil0003 | J.A.F. By Jafsupport.com | 6 | 11-04-2008 10:33 |
box problem - can't connect any phone with usb | eureka8888 | Infinity-Box | 8 | 01-08-2008 15:55 |
E1000: Force Boot Mode -> Phone not detected | dmg2 | Motorola P2k | 1 | 01-31-2006 14:16 |
Pls help i can't access any phone with my computer | macdan | Nokia Multimedia | 0 | 02-23-2005 21:03 |
