Old 09-01-2008, 09:10   #1 (permalink)
alfred_smd's Avatar
Member: 271133
Thanks Meter: 37
HELP can't read code mito 200
COM4 [VCP0] selected
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:E803:0005
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: E890_EVSMT3B.01.1
Version: EVEN6225_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35516282025023
connection Ok
detecting structure #1...
1 2 5 8 9 10 12 13 14 15 16 17 20 23 24 25 27 28warning: wrong packet cs
29error: detection failed (19 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 15 sec
Remove/Install battery now !
Old 09-01-2008, 19:12   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try complete format instead
Old 09-02-2008, 03:19   #3 (permalink)
alfred_smd's Avatar
Member: 271133
Thanks Meter: 37
thank.s infinity nom phone is ok
COM4 [VCP1] selected
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
boot step size: 0400
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: E307_JQINOV_MT6225S00.GM_01_0_20080723.BIN
ver. sw2: E307_JQINOV.GM.01.0, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 29 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-06-2009, 17:00   #4 (permalink)
Member: 592795
Please upload file mito 200 that you can read from your phone !
Please ! Please !
Old 09-05-2013, 06:45   #5 (permalink)
Member: 1626145
Thanks Meter: 15
mito 200 coolsand cpu - Download - 4shared
blackberry storm 9500 can't read code ,need help!! [SOLVED] xiongfuchen PolarBox 3 2 02-15-2010 18:07
J230i can't read codes patric Cruiser Suite 13 04-10-2007 15:43
can't read codes from My-X5-2 piracik SAGEM JTAG UNLOCKER 5 01-16-2007 19:36
philips 855 can't read codes???? midou01 Redbox 6 06-29-2006 11:37
i can't read code t600 by total tool pls help??? proxy_gsm Sony Ericsson 0 01-15-2004 10:23
Page generated in 0.14170 seconds with 9 queries
